Revit API Forum
Welcome to Autodesk’s Revit API Forums. Share your knowledge, ask questions, and explore popular Revit API topics.
Pipe Minimum Length
1 REPLY 1
ridaabderrahmane
136 Views, 1 Reply
Pipe Minimum Length
ridaabderrahmane
Hello everyone,
when I create a pipe with the API, I verify that its length is superior to the application short curve tolerance defined by the API (application.ShortCurveTolerance). Otherwise I display a message to the user that the pipe cannot be drawn.
But id I create a pipe and then I create a fitting (tee or elbow) the pipe gets shorter (the fitting takes from the length of the pipe) and even if I did the length verification I get a warning message by Revit telling me that the pipe was too short and needs to be deleted whiche is not what I want.
So I want to know how much length the tee or the elbow takes from the pipe so that I can do my verification properly.
If anyone have an idea about this problem I would highly appreciate your help.
Thanks in advance
Pipe Minimum Length
Hello everyone,
Thanks in advance
1 REPLY 1
jeremy_tammik
Yes, sure. Try it out, like this:
The minimum pipe length almost certainly depends on the specific fitting and its properties. Maybe you can use those properties to calculate the specific minimum pipe length on a per-fitting basis. Please let us know what you find out and how you end up solving this. Thank you!
