pipe dimensions
pipe dimensions
pipe dimensions
Dear Members,
Trying to create dimension for a pipe.
using (Transaction tx = new Transaction(doc))
                tx.Start("Transaction Name");
                foreach (ElementId eid in sel.GetElementIds())
                    //Debug.Print(e.Name);
                    try
                        SketchPlane sketch = doc.ActiveView.SketchPlane;
                        Pipe pp = doc.GetElement(eid) as Pipe;
                        LocationCurve lc = pp.Location as LocationCurve;
                        Line newLine2 = Line.CreateBound(lc.Curve.GetEndPoint(0) , lc.Curve.GetEndPoint(1));
                        ReferenceArray ra = new ReferenceArray();
                        ra.Append(newLine2.GetEndPointReference(0));
                        ra.Append(newLine2.GetEndPointReference(1));
                        int tt = pp.ConnectorManager.Connectors.Size;
                        Dimension newDimension = doc.Create.NewDimension(doc.ActiveView, newLine2, ra);
                    catch (Exception ee)
                tx.Commit();
Error:Inavlid Number of references
Thanks & Regards
Sanjay Pandey
recepagah12
I think this is your solution.
End Point Reference
I hope this helps,
Recep.
Yes That did the trick.
But its not creating dimension for vertical pipes.
Thanks & Regards
Sanjay Pandey
