Exception: "Input type is not a recognized Revit API type"
I'm trying to fetch all walls/floors/ceiling/etc using the following code:
Assembly DLL = Assembly.LoadFile("C:/Program Files/Autodesk/Revit 2019/RevitAPI.dll");
Type type = DLL.GetType("Autodesk.Revit.DB." + typeName);
FilteredElementCollector hostObjects = new FilteredElementCollector(Document).OfClass(type);
But i get an exception:
Autodesk.Revit.Exceptions.ArgumentException
  HResult=0x80131500
  Message=Input type(Autodesk.Revit.DB.Wall) is not a recognized Revit API type
Parameter name: type
Any idea why this code doesn't work?
atis.sed
I have stumbled upon same error, did you find out what was the cause ?
ricaun
This is a very old post and a quick answer should be used typeof(Wall) to get the type you want:
var allWalls = new FilteredElementCollector(Document).OfClass(typeof(Wall));
Luiz Henrique Cassettari
ricaun.com - Revit API Developer
AppLoader EasyConduit WireInConduit ConduitMaterial CircuitName ElectricalUtils
atis.sed
In my case I want to get Types from StringCollention, add to List, then feed that List into ElementMulticlassFilter:
List<Type> types = new List<Type>();
string message = null;
Assembly DLL = Assembly.LoadFile("C:/Program Files/Autodesk/Revit 2023/RevitAPI.dll");
foreach (string i in Settings1.Default.Family_Types)
 Type type = DLL.GetType("Autodesk.Revit.DB." + i);
 message = message + type.ToString() + "\n";
 types.Add(type);
TaskDialog.Show("types", message);
ElementMulticlassFilter TypeFilter = new ElementMulticlassFilter(types);
Interestingly, when I print the message, the names for the Types are correct.
In my case they are:
Yet, the ElementMulticlassFilter throws an error:
Autodesk.Revit.Exceptions.ArgumentException: 'Input type(Autodesk.Revit.DB.WallType) is not a recognized Revit API type
Parameter name: type'
ricaun
First, you should never use Assembly.LoadFile if you don't know the consequences.
Use this to get the assembly that is already loaded in Revit.exe instead of loading a new one.
Assembly DLL = typeof(Autodesk.Revit.DB.Document).Assembly;
or like your example:
[Transaction(TransactionMode.Manual)]
public class CommandTypeByName : IExternalCommand
    public Result Execute(ExternalCommandData commandData, ref string messages, ElementSet elementSet)
        UIApplication uiapp = commandData.Application;
        var Family_Types = new string[] { "WallType", "FloorType", "RoofType", "CeilingType" };
        foreach (string i in Family_Types)
            types.Add(type);
        return Result.Succeeded;
atis.sed
Thank you, this works perfectly!
