Perform command for Checked treenodes and roll back for unchecked treenodes
201606594
Message 1 of 11
201606594
Hi!
I have made a windows form featuring a treeview, that is populated with a list of walls instances in my document when opened. I would like to make a drawing of lines marking the wall instance whenever this is checked in the treeview. I have the script for the drawing however i do not know, how this is to be set up. How do I make the document aware that a treenode has been selected og deselected thus the wall is either drawn or removed in Revit, while the windows forms is open? Currently, the drawing works through a simple external command, but I want to make a connection with the tree nodes. Is this possible? Can I set up a transaction in the Forms script or do you have other suggestions?
Accepted solutions (3)
Replies (10)
Message 2 of 11
jeremy_tammik
I would suggest completely and utterly separating your user interface (the form) from your database interaction (the transaction, and the Revit API in general).
I would suggest implementing the form to just generate a list of element ids or some other data. Once the form has been closed, communicate this UI result to the completely separate subsequent database processing step.
Message 3 of 11
smarente1
Sounds like you need a modeless form. There are a handful of examples online.
Here is one that helped me:
https://forums.autodesk.com/t5/revit-api-forum/modeless-form-example/td-p/5800785
Message 4 of 11
201606594
Hi guys!
Thank you both for the answers! I have managed to get my externaleventhandler running and make changes in the model through a transaction from my forms window. However, I would like to have the option to rollback this transaction when pressing the button again. Do you have any suggestions how to do this?Screenshot_6.jpg
^This is what I've got so far. If necessary I can upload some of the code.
Message 5 of 11
jeremy_tammik
Nice. I like your screen snapshot.
Tricky. Your external command handler terminated and committed its transaction. That is just as if Revit had completed a built-in command. The only way to undo it is to use the Undo command:
https://thebuildingcoder.typepad.com/blog/2015/09/family-category-element-ids-transaction-undo-and-u...
Message 6 of 11
201606594
Hi Jeremy,
Thanks for the reply! I have considered the undo-options, however if eg. the visual style is changed before applying the undo command, this will be reverted instead. Is there a way to choose which transaction to undo?
Another option I've considered is simply selecting all model lines and deleting them though I don't know what effect it will have on the rest of the model.
A third option could be drawing all model lines beforehand and then turning them visible and invisble.
Do you have any suggestions regarding these options?
Message 7 of 11
jeremy_tammik
No. Not afaik.
might make some users very unhappy not to say furious.
> third option could be drawing all model lines beforehand and then turning them visible and invisible.
Fourth option: mark your model lines somehow, e.g., with a special line style or by adding an extensible storage data marker. Then you can delete them at will without destroying other user's work.
There are only about 42 million other possible approaches that we have also not considered yet.
Message 8 of 11
201606594
Great, I'll go for the fourth option then. Ive tried to look at the ElementParameterFilter and the example. However, the parametervalue i will be filtering for is LINE_PEN, which i do not know which filterrule to apply to it.
public class MyElementParameterFilter : IExternalCommand
        public Result Execute(ExternalCommandData commandData, ref string message, ElementSet elements)
            Document doc = commandData.Application.ActiveUIDocument.Document;
            UIDocument uidoc = commandData.Application.ActiveUIDocument;
            // Creates an ElementParameter filter
            // Create filter by provider and evaluator
            // provider
            ParameterValueProvider pvp = new ParameterValueProvider(new ElementId(BuiltInParameter.LINE_PEN));
            // evaluator
            FilterNumericRuleEvaluator fnrv = new FilterNumericEquals();
            // rule value
            double ruleValue = 100.0; // filter Model Lines equal to
                                      // rule
            FilterRule fRule = new FilterDoubleRule(pvp, fnrv, ruleValue, 1E-6);
            // Create an ElementParameter filter
            ElementParameterFilter filter = new ElementParameterFilter(fRule);
            // Apply the filter to the elements in the active document
            FilteredElementCollector collector = new FilteredElementCollector(doc);
            IList<Element> rooms = collector.WherePasses(filter).ToElements();
            ElementParameterFilter EqualFilter = new ElementParameterFilter(fRule, true);
            IList<Element> EqualFounds = collector.WherePasses(EqualFilter).ToElements();
            return Result.Succeeded;
 Do you have any suggestions?
Message 9 of 11
jeremy_tammik
Nope. I do not understand your question or how you intend to use the LINE_PEN parameter value.
Message 10 of 11
201606594
I tried to use a unique line weight (so far) as parametervalue and identify it via the builtinparameter(LINE_PATTERN, LINE_COLOR, LINE_PEN) but this might not be the right approach to this?
How would one assign this and identify it?
Message 11 of 11
201606594
I decided on storing the model lines in list upon creating them which I then emptied and deleted its contents when starting a new transaction. This seems to solve the problem.
