Pause an Event
Pause an Event
aclarke
Pause an Event
aclarke
Hi all,
I am curious to know why my event keeps firing?
In my command I show how I am registering and unregistering.
My event keeps firing after the unregister, If I close the document the event stops.  But I want to stop the event with a command in my current open document.
// | Test Function Command |
[Transaction(TransactionMode.Manual)]
internal class Cmd_RefreshFreeSize : IExternalCommand
    public Result Execute(ExternalCommandData commandData, ref string message, ElementSet elements)
        UIApplication uiapp = commandData.Application;
        Application app = commandData.Application.Application;
        Document doc = commandData.Application.ActiveUIDocument.Document;
        // To Register Event
        commandData.Application.ViewActivated += new EventHandler<Autodesk.Revit.UI.Events.ViewActivatedEventArgs>(Assembly.OnViewActivated);
        // To UnRegister Event
        commandData.Application.ViewActivated -= Assembly.OnViewActivated;
        return Result.Succeeded;
// | Function |
internal static class Assembly
    internal static void OnViewActivated(object sender, Autodesk.Revit.UI.Events.ViewActivatedEventArgs e)
        UIApplication uiapp = sender as UIApplication;
        View view = uiapp.ActiveUIDocument.ActiveView;
        if (view.IsAssemblyView)
            Assembly.MessageBox(view.IsAssemblyView.ToString());
        else
                MessageBox("not an assembly");
    // | Task Dialog |
    internal static TaskDialogResult MessageBox(string str)
        return TaskDialog.Show("Task", str);
    internal static TaskDialogResult MessageBox(object obj)
        return TaskDialog.Show("Task", $"{obj}");
aclarke
I am testing my code with the AddIn Manager, it has something to do with how the AddIn Manager works.  Seems each run is independent of the last run.
I hope to find more explanation.
ricaun
My first extinct was related to the new EventHandler, try to use the same event pattern.
commandData.Application.ViewActivated += Assembly.OnViewActivated;
I don't know what version of the AddInManager you are using, but I know an old version that I used has some problems with static code.
That's why I created my own AddInManager to fix this static problem. By the way, I test your original code, and works fine, the event was unregistered like should be.
The plugin is called AppLoader.
[video]
Luiz Henrique Cassettari
ricaun.com - Revit API Developer
AppLoader EasyConduit WireInConduit ConduitMaterial CircuitName ElectricalUtils
aclarke
Thanks for the feed back
I checked out your video(s) and website, you're doing some pretty cool stuff man!!
aclarke
here's something strange.  If I load the code this way thru add-in manager
First load works fine.
Second load does not unregister the first load, so it fires twice, which is what my OP is about.
But the strange part is not only does it fire twice on view change, it also jumps back to the original view I was first on and fires twice then jumps back to the selected view and fires twice once again???
ricaun
AddinManager works like this: Every time you execute a command the AddinManager gonna creates a new copy of that dll/assembly and gonna executes that command.
If you have 2 commands one to add the event and the other to remove the event, and if AddinManager creates a new assembly for each time it executes a command, the remove event command gonna try to remove an event that is not registered yet.
Usually is a bad idea add/remove events using IExtenalCommand, and if I do, I always remove the event in the IExternalApplication shutdown. This makes sure the event gonna be removed properly.
If you do not remove the event properly, you gonna have an event stuck until you close your Revit.
