Passing variables to a form
New to the Revit API so please excuse what is probably a very simple task.
How do I pass a variable from the current Revit session to a form. For example, if I wanted to pass the current Revit Version to a label that would show up in a form.
I can extract the version into a variable that I can display in a taskdialog:
  string verNum = app.VersionNumber;
TaskDialog.Show("Version Number", verNum);
but I can't seem to pass the to a form
rosalesduquej
Hi Tbh,
Can this be solve by just making the variable you are assigning the Revit Version a public variable, so you can access it from the class you are creating to do your form?
public string verNum;
A little info about public variables below.
Public variables can be used in any procedures in the project. If a public variable is declared in a standard module or a class module, it can also be used in any projects that reference the project where the public variable is declared.
https://msdn.microsoft.com/en-us/library/office/gg264241.aspx?f=255&MSPPError=-2147217396
Is this what you meant ? Cheers and hope everything goes well.
Jaime Rosales D.
Sr. Developer Consultant
Twitter | AEC ADN DevBlog
Revitalizer
you could pass the variable as a parameter in your Form's constructor.
Also, you could add some SetWhatEver(yourParameter) methods to your Form class to modify it after creation.
Revitalizer
Rudolf Honke
Software Developer
Mensch und Maschine
Aaron.Lu
There are a lot of ways to do that:
1. pass the parameters with the Form constructor, e.g.
public MyWinForm(string verion):Form(){}
2. pass via form properties, e.g.
MyWinForm form = new MyWinForm();
form.RvtVersion = "xxx";
3. use static members outside of the form, e.g.
public MyCommand: IExternalCommand
public static string Version;
public Result Exeucte(...)
Version = ...;
Aaron Lu
Developer Technical Services
Autodesk Developer Network
your comman class, creat a public static variable
E.G
namespace MyCommand{
           public class Command : IExternalCommand
                     public static string LabelName;
                     public Result Execute(
                     ExternalCommandData commandData,
                     ref string message,
                     ElementSet elements)
then in your form.cs when you want to call the string use
label1.text = MyCommand.Command.LabelName;
hope this helps
That turned out to be the issue. I wasn't making my variable public. I ended up creating a subclass that generated a public variable and passed it to the label. Made sense once I figured out the problem.
Got my first 'useable' addin complete. Nice to get back into the programming side after so many years away.
Appreciate everyones feedback.
