Parking Component
Dear Sir,
I need to know how to access Parking component while scripting as I reference for example Room , I will list down the script I have and where I am stuck(Red Color)
if (Current is Room)
what should i use instead of <room> to access <parking component>
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using Autodesk.Revit.UI;
using Autodesk.Revit.DB;
using Autodesk.Revit.DB.Architecture;
using Autodesk.Revit.UI.Selection;
using System.Windows.Forms;
using System.Collections;
using System.Diagnostics;
using System.Runtime.InteropServices;
using System.Threading;
namespace CarPark_Renumbering
[Autodesk.Revit.Attributes.Transaction(Autodesk.Revit.Attributes.TransactionMode.Manual)]
[Autodesk.Revit.Attributes.Regeneration(Autodesk.Revit.Attributes.RegenerationOption.Manual)]
[Autodesk.Revit.Attributes.Journaling(Autodesk.Revit.Attributes.JournalingMode.NoCommandData)]
public class Command : IExternalCommand
#region IExternalCommand Members
Document doc;
UIDocument uiDoc;
UIApplication uiApp;
List<CarParkObject> allParks = new List<CarParkObject>();
public Result Execute(ExternalCommandData commandData, ref string message, Autodesk.Revit.DB.ElementSet elements)
try
//getting the document
uiApp = commandData.Application;
String licMsg = "";
if (isLic(out licMsg))
uiDoc = uiApp.ActiveUIDocument;
doc = uiDoc.Document;
//renumbering option (Selection or Insertion)
MainWindow selectionWindow = new MainWindow();
selectionWindow.ShowDialog();
if (SelectionResult.SelectedResult == SelectionResult.Result.RenumberInsert)
selectionWindow.Close();
renumberInsPark();
else if (SelectionResult.SelectedResult == SelectionResult.Result.IndividualRooms)
pickParksIndividual(allParks);
if (allParks.Count == 0)
message = "No Car Parks Available";
return Result.Cancelled;
renumberSelectedPark();
else if (SelectionResult.SelectedResult == SelectionResult.Result.WindowSelect)
pickParksByWindow(allParks);
message = "No Parks Available";
allParks.Sort();
else
return Result.Succeeded;
else
message = "Invalid License\n" + licMsg;
catch (OperationCanceledException x)
message = x.Message;
catch (Exception x)
return Result.Failed;
/// <summary>
/// check if the application is to be run
/// </summary>
/// <param name="message">the message if an error occurs</param>
/// <returns></returns>
private bool isLic(out String message)
bool retval = false;
try
retval = true;
message = "";
catch (Exception x)
message = "Error reading the License\n" + x.Message;
return retval;
//renumber parks based on the selection alg.
private void renumberSelectedPark()
//display the park renumbering form and renumber parks
CarParkRenumber renumberDisplay = new CarParkRenumber(ref allParks, uiApp);
if (renumberDisplay.ShowDialog() == DialogResult.OK)
using (Transaction trans = new Transaction(doc))
if (trans.Start("Renumbering Parks") == TransactionStatus.Started)
if (!RenumberParks())
throw new Exception("Cannot Have an Empty Park Number");
trans.Commit();
//pop up a task dialog to get information from the user regarding the renumbering option (by selection or based on room insertion)
private TaskDialogResult renumberOption()
TaskDialogResult result;
try
TaskDialog renumberOptionDialog = new TaskDialog("KA Arch Application | Car Park Renumbering");
renumberOptionDialog.TitleAutoPrefix = false;
renumberOptionDialog.MainInstruction = "Renumber Options";
//add commandlinks
renumberOptionDialog.AddCommandLink(TaskDialogCommandLinkId.CommandLink1, "Renumber Parks in a Selected Order");
renumberOptionDialog.AddCommandLink(TaskDialogCommandLinkId.CommandLink2, "Insert a Park Number and Renumber Affected Parks");
//show the task dialog
result = renumberOptionDialog.Show();
catch (Exception x)
throw new Exception(x.Message);
return result;
//pop up a taks dialog to get information about the selection method
private TaskDialogResult renumberSelection()
try
TaskDialog renumberSelectionDialog = new TaskDialog("KA Arch Application | Car Park Renumbering");
renumberSelectionDialog.TitleAutoPrefix = false;
renumberSelectionDialog.MainInstruction = "Renumber Selection Method";
//add commandlinks
renumberSelectionDialog.AddCommandLink(TaskDialogCommandLinkId.CommandLink1, "Pick Individual Park or Park Tags");
renumberSelectionDialog.AddCommandLink(TaskDialogCommandLinkId.CommandLink2, "Window Select Parks or Park Tags");
result = renumberSelectionDialog.Show();
catch (Exception x)
return result;
//pick parks individually
private void pickParksIndividual(List<CarParkObject> parks)
try
//filter parks and park tags
ParkSelectionFilter parkFilter = new ParkSelectionFilter();
//pick objects
Reference r = uiDoc.Selection.PickObject(ObjectType.Element, parkFilter, "Pick Park or Park Tag to renumber, based on the selection order");
while (r != null)
Element current = doc.GetElement(r);
if (current is Room)
addParkToList((current as Room), parks);
else if (current is RoomTag)
addParkToList((current as RoomTag).Room, parks);
try
catch (Exception)
r = null;
catch (Exception x)
throw new OperationCanceledException(x.Message);
//pic parks by window
private void pickParksByWindow(List<CarParkObject> parks)
try
//pick objects
IList<Element> pickedObjects = uiDoc.Selection.PickElementsByRectangle(parkFilter, "pick parks by rectangle");
for (int i = 0; i < pickedObjects.Count; i++)
Element current = pickedObjects[i];
catch (Exception x)
private void addParkToList(Room r, List<CarParkObject> list)
try
CarParkObject obj = new CarParkObject(r);
bool exists = false;
//compare based on the ID
foreach (CarParkObject temp in list)
if (temp.ID == obj.ID)
exists = true;
//add if does not exist
if (!exists)
list.Add(obj);
catch (Exception x)
throw new Exception("Error adding Car Park to the list: \"" + r.Name + "\" to the list\n" + x.Message);
//renumber the parks
private bool RenumberParks()
try
// Find all views in the document by using category filter
ElementCategoryFilter filter = new ElementCategoryFilter(BuiltInCategory.OST_Parking);
// Apply the filter to the elements in the active document,
FilteredElementCollector collector = new FilteredElementCollector(doc);
FilteredElementIterator iter = collector.WherePasses(filter).GetElementIterator();
iter.Reset();
//Iterate through the parks in the document
while (iter.MoveNext())
Room CurrentPark = iter.Current as Room;
//The selected instance is a door
if (CurrentPark != null)
foreach (CarParkObject x in allParks)
if (x.ID == CurrentPark.Id.IntegerValue.ToString())
if (x.NewNumber == "")
return false;
else
//Renumber the parks
CurrentPark.Number = x.NewNumber;
// modified by Ramzi Al Halaby on 06-06-2015 while upgrading to Revit 2016
CurrentPark.LookupParameter("FN").Set(x.LevelNumber);
CurrentPark.LookupParameter("DP").Set(x.DepartmentNumber);
CurrentPark.LookupParameter("RN").Set(x.RoomNum);
//CurrentPark.get_Parameter("FN").Set(x.LevelNumber);
//CurrentPark.get_Parameter("DP").Set(x.DepartmentNumber);
//CurrentPark.get_Parameter("RN").Set(x.RoomNum);
return true;
catch (Exception x)
throw new Exception("Error in renumbering\n" + x.Message);
//renumber parks based on the insertion alg.
private void renumberInsPark()
RetreiveallParks();
throw new Exception("No parks Available");
allParks.Sort();
Room selected = null;
if (PickTheParkToBeInserted(ref selected))
int index = GetIndexOfSelectedPark(selected);
if (index != -1)
CarParkInsert insertDisplay = new CarParkInsert(ref allParks, uiApp, index);
if (insertDisplay.ShowDialog() == DialogResult.OK)
if (trans.Start("Renumbering parks") == TransactionStatus.Started)
trans.Commit();
else
throw new Exception("Selected Park is invalid");
//retrieve all parks in the view
private void RetreiveallParks()
try
FilteredElementCollector collector = new FilteredElementCollector(doc, doc.ActiveView.Id);
iter.Reset();
CarParkObject CurrentCarParkObject = new CarParkObject(CurrentPark);
allParks.Add(CurrentCarParkObject);
catch (Exception)
TaskDialog.Show("KA Arch | parks Renumbering", "Error in Retreiving parks from the Revit Model!!", TaskDialogCommonButtons.Ok);
//pick the park to be inserted
private bool PickTheParkToBeInserted(ref Room SelectedPark)
try
Reference PickedObject = uiDoc.Selection.PickObject(Autodesk.Revit.UI.Selection.ObjectType.Element, new ParkSelectionFilter(), "Pick the park to be inserted for renumbering.");
// Modified by Ramzi on 08-06-2015 (changed method for getting current selected park)
//if (PickedObject.Element != null)
if (doc.GetElement(PickedObject) != null)
//Element Current = PickedObject.Element;
Element Current = doc.GetElement(PickedObject);
SelectedPark = Current as Room;
else if (Current is RoomTag)
SelectedPark = (Current as RoomTag).Room;
else
TaskDialog.Show("KA Arch App | parks Renumbering", "The Selected item is not a Park!", TaskDialogCommonButtons.Ok);
return false;
return true;
catch (Exception x)
//Get the index of the selected park to be inserted.
private int GetIndexOfSelectedPark(Room SelectedPark)
try
int index = -1;
for (int i = 0; i < allParks.Count; i++)
if (allParks[i].ID == SelectedPark.Id.IntegerValue.ToString())
index = i;
break;
return index;
catch (Exception)
TaskDialog.Show("KA Arch App | parks Renumbering", "The park doesn't exist in the list..", TaskDialogCommonButtons.Ok);
return -1;
#endregion
//implements the ISelection filter for parks and park tags
public class ParkSelectionFilter : ISelectionFilter
#region ISelectionFilter Members
public bool AllowElement(Element elem)
if (elem.Category.Name == "Rooms" || elem.Category.Name == "Room Tags")
return true;
return false;
public bool AllowReference(Reference reference, XYZ position)
return true;
#endregion
