Parking Component
Parking Component
rahalabi
Parking Component
rahalabi
Dear Sir,
I need to know how to access Parking component while scripting as I reference for example Room , I will list down the script I have and where I am stuck(Red Color)
             if (Current is Room)
what should i use instead of <room>  to access <parking component>
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using Autodesk.Revit.UI;
using Autodesk.Revit.DB;
using Autodesk.Revit.DB.Architecture;
using Autodesk.Revit.UI.Selection;
using System.Windows.Forms;
using System.Collections;
using System.Diagnostics;
using System.Runtime.InteropServices;
using System.Threading;
namespace CarPark_Renumbering
    [Autodesk.Revit.Attributes.Transaction(Autodesk.Revit.Attributes.TransactionMode.Manual)]
    [Autodesk.Revit.Attributes.Regeneration(Autodesk.Revit.Attributes.RegenerationOption.Manual)]
    [Autodesk.Revit.Attributes.Journaling(Autodesk.Revit.Attributes.JournalingMode.NoCommandData)]
    public class Command : IExternalCommand
        #region IExternalCommand Members
        Document doc;
        UIDocument uiDoc;
        UIApplication uiApp;
        List<CarParkObject> allParks = new List<CarParkObject>();
        public Result Execute(ExternalCommandData commandData, ref string message, Autodesk.Revit.DB.ElementSet elements)
            try
                //getting the document
                uiApp = commandData.Application;
                String licMsg = "";
                if (isLic(out licMsg))
                    uiDoc = uiApp.ActiveUIDocument;
                    doc = uiDoc.Document;
                    //renumbering option (Selection or Insertion)
                    MainWindow selectionWindow = new MainWindow();
                    selectionWindow.ShowDialog();
                    if (SelectionResult.SelectedResult == SelectionResult.Result.RenumberInsert)
                        selectionWindow.Close();
                        renumberInsPark();
                    else if (SelectionResult.SelectedResult == SelectionResult.Result.IndividualRooms)
                        pickParksIndividual(allParks);
                        if (allParks.Count == 0)
                            message = "No Car Parks Available";
                            return Result.Cancelled;
                        renumberSelectedPark();
                    else if (SelectionResult.SelectedResult == SelectionResult.Result.WindowSelect)
                        pickParksByWindow(allParks);
                            message = "No Parks Available";
                        allParks.Sort();
                    else
                    return Result.Succeeded;
                else
                    message = "Invalid License\n" + licMsg;
            catch (OperationCanceledException x)
                message = x.Message;
            catch (Exception x)
                return Result.Failed;
        /// <summary>
        /// check if the application is to be run
        /// </summary>
        /// <param name="message">the message if an error occurs</param>
        /// <returns></returns>
        private bool isLic(out String message)
            bool retval = false;
            try
                retval = true;
                message = "";
            catch (Exception x)
                message = "Error reading the License\n" + x.Message;
            return retval;
        //renumber parks based on the selection alg.
        private void renumberSelectedPark()
            //display the park renumbering form and renumber parks
            CarParkRenumber renumberDisplay = new CarParkRenumber(ref allParks, uiApp);
            if (renumberDisplay.ShowDialog() == DialogResult.OK)
                using (Transaction trans = new Transaction(doc))
                    if (trans.Start("Renumbering Parks") == TransactionStatus.Started)
                        if (!RenumberParks())
                            throw new Exception("Cannot Have an Empty Park Number");
                        trans.Commit();
        //pop up a task dialog to get information from the user regarding the renumbering option (by selection or based on room insertion)
        private TaskDialogResult renumberOption()
            TaskDialogResult result;
            try
                TaskDialog renumberOptionDialog = new TaskDialog("KA Arch Application | Car Park Renumbering");
                renumberOptionDialog.TitleAutoPrefix = false;
                renumberOptionDialog.MainInstruction = "Renumber Options";
                //add commandlinks
                renumberOptionDialog.AddCommandLink(TaskDialogCommandLinkId.CommandLink1, "Renumber Parks in a Selected Order");
                renumberOptionDialog.AddCommandLink(TaskDialogCommandLinkId.CommandLink2, "Insert a Park Number and Renumber Affected Parks");
                //show the task dialog
                result = renumberOptionDialog.Show();
            catch (Exception x)
                throw new Exception(x.Message);
            return result;
        //pop up a taks dialog to get information about the selection method
        private TaskDialogResult renumberSelection()
            try
                TaskDialog renumberSelectionDialog = new TaskDialog("KA Arch Application | Car Park Renumbering");
                renumberSelectionDialog.TitleAutoPrefix = false;
                renumberSelectionDialog.MainInstruction = "Renumber Selection Method";
                //add commandlinks
                renumberSelectionDialog.AddCommandLink(TaskDialogCommandLinkId.CommandLink1, "Pick Individual Park or Park Tags");
                renumberSelectionDialog.AddCommandLink(TaskDialogCommandLinkId.CommandLink2, "Window Select Parks or Park Tags");
                result = renumberSelectionDialog.Show();
            catch (Exception x)
            return result;
        //pick parks individually
        private void pickParksIndividual(List<CarParkObject> parks)
            try
                //filter parks and park tags
                ParkSelectionFilter parkFilter = new ParkSelectionFilter();
                //pick objects
                Reference r = uiDoc.Selection.PickObject(ObjectType.Element, parkFilter, "Pick Park or Park Tag to renumber, based on the selection order");
                while (r != null)
                    Element current = doc.GetElement(r);
                    if (current is Room)
                        addParkToList((current as Room), parks);
                    else if (current is RoomTag)
                        addParkToList((current as RoomTag).Room, parks);
                    try
                    catch (Exception)
                        r = null;
            catch (Exception x)
                throw new OperationCanceledException(x.Message);
        //pic parks by window
        private void pickParksByWindow(List<CarParkObject> parks)
            try
                //pick objects
                IList<Element> pickedObjects = uiDoc.Selection.PickElementsByRectangle(parkFilter, "pick parks by rectangle");
                for (int i = 0; i < pickedObjects.Count; i++)
                    Element current = pickedObjects[i];
            catch (Exception x)
        private void addParkToList(Room r, List<CarParkObject> list)
            try
                CarParkObject obj = new CarParkObject(r);
                bool exists = false;
                //compare based on the ID
                foreach (CarParkObject temp in list)
                    if (temp.ID == obj.ID)
                        exists = true;
                //add if does not exist
                if (!exists)
                    list.Add(obj);
            catch (Exception x)
                throw new Exception("Error adding Car Park to the list: \"" + r.Name + "\" to the list\n" + x.Message);
        //renumber the parks
        private bool RenumberParks()
            try
                // Find all views in the document by using category filter
                ElementCategoryFilter filter = new ElementCategoryFilter(BuiltInCategory.OST_Parking);
                // Apply the filter to the elements in the active document,
                FilteredElementCollector collector = new FilteredElementCollector(doc);
                FilteredElementIterator iter = collector.WherePasses(filter).GetElementIterator();
                iter.Reset();
                //Iterate through the parks in the document
                while (iter.MoveNext())
                    Room CurrentPark = iter.Current as Room;
                    //The selected instance is a door
                    if (CurrentPark != null)
                        foreach (CarParkObject x in allParks)
                            if (x.ID == CurrentPark.Id.IntegerValue.ToString())
                                if (x.NewNumber == "")
                                    return false;
                                else
                                    //Renumber the parks
                                    CurrentPark.Number = x.NewNumber;
                                    // modified by Ramzi Al Halaby on 06-06-2015 while upgrading to Revit 2016
                                    CurrentPark.LookupParameter("FN").Set(x.LevelNumber);
                                    CurrentPark.LookupParameter("DP").Set(x.DepartmentNumber);
                                    CurrentPark.LookupParameter("RN").Set(x.RoomNum);
                                    //CurrentPark.get_Parameter("FN").Set(x.LevelNumber);
                                    //CurrentPark.get_Parameter("DP").Set(x.DepartmentNumber);
                                    //CurrentPark.get_Parameter("RN").Set(x.RoomNum);
                return true;
            catch (Exception x)
                throw new Exception("Error in renumbering\n" + x.Message);
        //renumber parks based on the insertion alg.
        private void renumberInsPark()
            RetreiveallParks();
                throw new Exception("No parks Available");
            allParks.Sort();
            Room selected = null;
            if (PickTheParkToBeInserted(ref selected))
                int index = GetIndexOfSelectedPark(selected);
                if (index != -1)
                    CarParkInsert insertDisplay = new CarParkInsert(ref allParks, uiApp, index);
                    if (insertDisplay.ShowDialog() == DialogResult.OK)
                            if (trans.Start("Renumbering parks") == TransactionStatus.Started)
                                trans.Commit();
                else
                    throw new Exception("Selected Park is invalid");
        //retrieve all parks in the view
        private void RetreiveallParks()
            try
                FilteredElementCollector collector = new FilteredElementCollector(doc, doc.ActiveView.Id);
                iter.Reset();
                        CarParkObject CurrentCarParkObject = new CarParkObject(CurrentPark);
                        allParks.Add(CurrentCarParkObject);
            catch (Exception)
                TaskDialog.Show("KA Arch | parks Renumbering", "Error in Retreiving parks from the Revit Model!!", TaskDialogCommonButtons.Ok);
        //pick the park to be inserted
        private bool PickTheParkToBeInserted(ref Room SelectedPark)
            try
                Reference PickedObject = uiDoc.Selection.PickObject(Autodesk.Revit.UI.Selection.ObjectType.Element, new ParkSelectionFilter(), "Pick the park to be inserted for renumbering.");
                // Modified by Ramzi on 08-06-2015 (changed method for getting current selected park)
                //if (PickedObject.Element != null)
                if (doc.GetElement(PickedObject) != null)
                    //Element Current = PickedObject.Element;
                    Element Current = doc.GetElement(PickedObject);
                        SelectedPark = Current as Room;
                    else if (Current is RoomTag)
                        SelectedPark = (Current as RoomTag).Room;
                    else
                        TaskDialog.Show("KA Arch App | parks Renumbering", "The Selected item is not a Park!", TaskDialogCommonButtons.Ok);
                        return false;
                return true;
            catch (Exception x)
        //Get the index of the selected park to be inserted.
        private int GetIndexOfSelectedPark(Room SelectedPark)
            try
                int index = -1;
                for (int i = 0; i < allParks.Count; i++)
                    if (allParks[i].ID == SelectedPark.Id.IntegerValue.ToString())
                        index = i;
                        break;
                return index;
            catch (Exception)
                TaskDialog.Show("KA Arch App | parks Renumbering", "The park doesn't exist in the list..", TaskDialogCommonButtons.Ok);
                return -1;
        #endregion
    //implements the ISelection filter for parks and park tags
    public class ParkSelectionFilter : ISelectionFilter
        #region ISelectionFilter Members
        public bool AllowElement(Element elem)
            if (elem.Category.Name == "Rooms" || elem.Category.Name == "Room Tags")
                return true;
            return false;
        public bool AllowReference(Reference reference, XYZ position)
            return true;
        #endregion
Thanks for sharing this code!
andrew_parrella
Hi Rahalabi,
Parking components are category OST_Parking, I think you have to access it through the category. Hope that helps.
Andy
Andy P
Principal QA Analyst - Revit
rahalabi
I have used it as shown below:
            try
                iter.Reset();
                                    return false;
                                else
                return true;
            catch (Exception x)
but if I want to  create something like this
how will I do it?
Revitalizer
it's a FamilyInstance (of BuiltInCategory.OST_Parking, as Andrew already pointed out).
You may use RevitLookup to find that out by yourself.
Revitalizer
Rudolf Honke
Software Developer
Mensch und Maschine
