Parameter Filter
Parameter Filter
vanlion
Message 1 of 9
Parameter Filter
vanlion
I want to get all generic families that contains for example "test" in the name and show this in a windowsform combobox so i can use it in a form to set parameters etc. My thought was to do this with a parameter filter. I came this far as shown below this post. But how do you add the filter to the GenericFamilySymbolList? i tried collector.WherePasses(filter); But i get no results in the combobox . Without the filter everything works and shows all the generic models. but i need only the ones with test in the name (as example)
. Anyone an idea what i'm missing?
            IList<Element> GenericFamilySymbolList = new List<Element>();
            FilteredElementCollector collector = new FilteredElementCollector(doc);
            ////// Get Family Category//////
            //GenericFamilySymbolList =collector.OfClass(typeof(FamilySymbol)).OfCategory(BuiltInCategory.OST_GenericModel).ToElements();
            ElementId id = new ElementId(BuiltInParameter.DATUM_TEXT);
            ParameterValueProvider provider = new ParameterValueProvider(id);
            FilterStringRuleEvaluator evaluator = new FilterStringContains();
            FilterRule rule = new FilterStringRule(provider, evaluator, "test", true);
            ElementParameterFilter filter = new ElementParameterFilter(rule);
            GenericModelComboBox form = new GenericModelComboBox(GenericFamilySymbolList);
                form.ShowDialog();
Accepted solutions (4)
Replies (8)
Message 2 of 9
FAIR59
you are filtering for the wrong parameter. For the symbol.Name you need BuiltInParameter.ALL_MODEL_TYPE_NAME
Message 3 of 9
vanlion
Thanks for the reply. I Will try it with this BuiltInParameter. I think you have to end with : collector.WherePasses(filter)?
Message 4 of 9
vanlion
It's working 🙂
this is the solution:
                ElementId id = new ElementId(BuiltInParameter.ALL_MODEL_TYPE_NAME);
                FilterRule rule = new FilterStringRule(provider, evaluator, "test", false);
                GenericFamilySymbolList = collector.WherePasses(filter).ToElements();
Message 5 of 9
jeremytammik
Thank you very much for the nice little sample and solution.
It prompts me to reiterate for the umpteenth time:
There is generally no need to call ToElements on a filtered element collector.
You can use and iterate over the collector directly.
The conversion costs time and memory and brings no advantage whatsoever.
I mentioned it here and many, many other places:
http://thebuildingcoder.typepad.com/blog/2018/08/naveen-zhong-and-deleting-non-shared-project-parame...
Here is a version that skips the conversion:
  ElementId id = new ElementId( BuiltInParameter
    .ALL_MODEL_TYPE_NAME );
    = new ParameterValueProvider( id );
    provider, evaluator, "test", false );
    = new ElementParameterFilter( rule );
  FilteredElementCollector genericSymbolsNamedTest
    = new FilteredElementCollector( doc )
      .OfClass( typeof( FamilySymbol ) )
      .OfCategory( BuiltInCategory.OST_GenericModel )
      .WherePasses( filter );
I added your sample code to The Building Coder samples and optimised it there, so you can see the difference:
https://github.com/jeremytammik/the_building_coder_samples/compare/2019.0.143.8...2019.0.143.9
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
Message 6 of 9
vanlion
Hi Jeremy,
Thanks for the quick response!
Filter is working fine. But i used mine also to fill a combobox with this part:
    public partial class GenericModelComboBox : System.Windows.Forms.Form
        public GenericModelComboBox(
            IEnumerable<Element> GenericFamilySymbolList)
            InitializeComponent();
            comboBox1.DataSource = GenericFamilySymbolList;
            comboBox1.DisplayMember = "Name";
maybe a stupid beginners question 😉 But how bind it now to the combobox?
Message 7 of 9
vanlion
Sorry, already got it i think. It's shows up again in the combobox.
List<Element> genericSymbolsNamedTest = new List<Element>
(new FilteredElementCollector(doc)
.WherePasses(filter));
Message 8 of 9
jeremytammik
Good!
Maybe better:
  IList<Element> genericSymbolsNamedTest
      .ToElements();
As you see, we are back to calling ToElements again, but AFTER all filtering has completed. so the number of elements is minimised.
Hoping that the built-in `ToElements` implementation is at least as efficient as calling `new List<...>` yourself.
Cheers,
Jeremy
Jeremy Tammik
The Building Coder
Message 9 of 9
vanlion
Works nice!!!
This is helping me a lot so thank you.
