Dear Guys, I am very new to use Dynamo and trying sometimes I still don't clearly understand the functionality of nodes when:
- Dynamo is using -double- as output ( that's why I didn't use the commande Height Spaces) and
- how to override the height parameter ( in this case " Offset limite") to another value, to all the elements in the model. Did it also requires to select the elements with another command?
Best Regards.
