Override Parameters by value-->Spaces
lorenzomasottiarchitetto
Dear Guys, I am very new to use Dynamo and trying sometimes I still don't clearly understand the functionality of nodes when:
- Dynamo is using -double- as output ( that's why I didn't use the commande Height Spaces) and
- how to override the height parameter  ( in this case " Offset limite") to another value, to  all the elements in the model. Did it also requires to select the elements with another command?
Best Regards.
manhgt214
This is RevitAPI so please post in Dynamo forum
Dynamo
In the case of you:
Codeblock node can't not contain Number and String, let's delete "mm" after 5100 then try again.
-> Element.SetParaByName is error so you can not get "Height" of them.
See error mark on the top of node is showing.
RevitAPI Tips & Trick:
https://youtube.com/@revitapi-easy
thanks, I don't find Dynamo forum, just MEP ora Architecture or API....inside Revit Forum...
ctm_mka
@lorenzomasottiarchitetto  literally click on the bolded underlined Dynamo in his reply, its a link.
RLY_15
To clarify - the Dynamo forums are not hosted on the Autodesk website but are instead their own website (though they do hook in with your Autodesk account). So you won't see it using the Community ribbon on this site. The link that was provided is the correct resource and is recommended, though if you post to Revit Architecture/MEP/Structure with Dynamo graphs related to those topics you'll generally be able to get support from users in those topics.
