Optimize performance while creating 3DViews and Filters.
mohd.fadel
mohd.fadel
I'm creating an add-in that creates views and add filters (which i also create via the api). On average, there are around 1000 views and 1000 filters added to each view. I found that CreateIsometric takes longer than duplicating the view using ActiveView.Duplicate(ViewDuplicateOption.Duplicate) so i decided to use Duplicate to create my views. However, adding the filters using AddFilter takes a lot of time. Is there any way to optimize my code? Here is a snippet of my code:
foreach (string tempName in allTempNames)
Element CreatedView = doc.GetElement(ActiveView.Duplicate(ViewDuplicateOption.Duplicate));
Autodesk.Revit.DB.View newView = doc.GetElement(CreatedView.Id) as Autodesk.Revit.DB.View;
newView.Name = tempName.Remove(phase.LastIndexOf('*'));
FilteredElementCollector viewCollector = new FilteredElementCollector(doc).OfClass(typeof(View3D));
            List<View3D> views3d = viewCollector.ToElements().Cast<View3D>().Where(x => x.IsTemplate == false).ToList();
            foreach (View3D view in views3d)
                if (allList.Any(a => a.name== view.Name))
                    foreach (LOE lo2 in allFilters)
                        view.AddFilter(lo2.filter_id);
Thank you in advance,
Mohamad.
jeremy_tammik
Yes, I see some (very minor) optimisation possibilities:
  • No need to call GetElement twice; use a cast instead of the second call
  • Eliminate the call to ToElements(); it serves no useful purpose and wastes both time and memory
  • Eliminate the call to ToList(); the same applies
  • Add benchmarking code to identify the bottleneck
I see no transactions; does all this code get executed within one single transaction?
I would suggest adding some benchmarking code:
https://www.google.com/search?q=benchmark&as_sitesearch=thebuildingcoder.typepad.com
With some reliable benchmarking results in hand, we can discuss further; if the problem makes sense and persists, please submit a complete minimal reproducible case for analysis.
mohd.fadel
Hello Jeremy,
Thank you for your reply. I tested my code multiple times. The bottleneck is in this code:
foreach (string test in allTest)
                        View3D view = viewCollector.Cast<View3D>().Where(x => x.Name == test.Remove(test.LastIndexOf('*'))).FirstOrDefault() as View3D;
                        foreach (ElementId id in allFiltersIds)
                            view.AddFilter(id);
Like i said, I have over a 1000 view and over a 1000 filter. Each view should add the 1000 filter. It is taking a lot of time over 2 hours. So you think there's anything that can be done?
Mohamad.
jeremy_tammik
Well, basically Revit was designed as an end-user product, so it is not optimised for being driven programmatically.
How long does this operation take manually in the UI? (Sorry, that was a joke.)
Have you discussed your approach with an application expert who has confirmed that you are indeed following best practices in performing this step?
If you like, you can submit a complete minimal reproducible test case for analysis by the development team:
https://thebuildingcoder.typepad.com/blog/about-the-author.html#1b
