OnProjectOpen Function?
coopgodd
coopgodd
Hey there,
I am currently using a WPF window and it opens when there is no project opened in Revit. That being said, to use the features of the WPF (collecting data from the floors of a project), it must be reloaded to/when a project is opened in Revit so that it actually collects the data.
Is there a built-in function within the Revit API or a way to have this WPF Page reload when a new project is opened?
Thank you!
paul.nelsonCDRHK
Something I found missing when I was trying to get a dockablepane WPF project up and running is how to get read/write access to the WPF interactively. The basics are, make sure the WPF is a WPF page and the class has IDockablePaneProvider as a partial class in the page.XAML.cs file.
using Autodesk.Revit.DB;
using Autodesk.Revit.UI;
using System;
using System.Collections.Generic;
using System.Linq;
using System.Runtime.InteropServices;
using System.Text;
using System.Threading.Tasks;
using System.Windows;
using System.Windows.Controls;
using System.Windows.Data;
using System.Windows.Documents;
using System.Windows.Input;
using System.Windows.Markup;
using System.Windows.Media;
using System.Windows.Media.Imaging;
using System.Windows.Navigation;
using System.Windows.Shapes;
using static System.Net.Mime.MediaTypeNames;
// too many includes here
namespace BIMAppRvt
    /// <summary>
    /// Interaction logic for SheetGenerator.xaml
    /// </summary>
    public partial class SheetGenerator : Page, IDockablePaneProvider
        private EventHandlers eventHandler;
        private ExternalEvent extEvent;
      //  public EventHandlers eventHandler;
      //  public ExternalEvent extEvent;
        public void SetupDockablePane(DockablePaneProviderData data)
            data.FrameworkElement = this as FrameworkElement;
            data.InitialState = new DockablePaneState();
            data.InitialState.DockPosition = DockPosition.Right;
            data.VisibleByDefault = false;
        public SheetGenerator(ExternalEvent exEvent, EventHandlers handlers)
            InitializeComponent();
            eventHandler = handlers;
            extEvent = exEvent;
in your main app, create class instances of the WPF page(s).
using System;
using System.Drawing;
using System.Linq;
using System.Text;
using System.IO;
using System.Reflection;
using Autodesk.Revit.ApplicationServices;
using Autodesk.Revit.Attributes;
using Autodesk.Revit.UI.Selection;
using Autodesk.Revit.DB.Architecture;
using Autodesk.Revit.DB.Events;
using System.Windows.Controls.Ribbon;
using Autodesk.Revit.UI.Events;
using Autodesk.Revit.DB.Mechanical;
using MessageBox = System.Windows.MessageBox;
using System.Security.Cryptography;
using System.Xml.Linq;
using ListViewItem = System.Windows.Controls.ListViewItem;
using System.Collections.Specialized;
using System.Windows.Controls.Primitives;
using Application = Autodesk.Revit.ApplicationServices.Application;
using System.Windows.Forms;
namespace BIMAppRvt
    public class BIMApp : IExternalApplication
        internal static BIMApp thisApp = null;
// add a class instance of each WPF page
        public static SheetGenerator SheetGenPane { get; set; }
        public static LegendCopy LegendCopyPane { get; set; }
// classes to initialise the dockablepanes
        public static DockablePaneId SheetGenPaneId { get { return new DockablePaneId(new Guid("4B7CFCA2-8F4C-45E5-9E3E-E3E732E04659")); } }
        public static DockablePaneId LegendCopyPaneId { get { return new DockablePaneId(new Guid("3DE4A629-7774-4C9E-A6FE-FF2001C78669")); } }
        public static DataGridRow dgr { get; set; }
        public static Document cDoc = null;
//static list of all the dockablepanes
        public static List<DockablePaneId> DockPanes()
            List<DockablePaneId> dPlist = new List<DockablePaneId>();
            dPlist.Clear();
            dPlist.Add(SheetGenPaneId);
            dPlist.Add(LegendCopyPaneId);
            return dPlist;
        public Result OnShutdown(UIControlledApplication application)
            return Result.Succeeded;
        public Result OnStartup(UIControlledApplication application)
            thisApp = this;  // static access to this application instance
            Utilities utilities = new Utilities();
// declare the event handlers to allow revit commands to be run from the pane
            EventHandlers handlers = new EventHandlers();
            ExternalEvent exEvent = ExternalEvent.Create(handlers);
// create Instances of docakble panes
            SheetGenerator sPane = new SheetGenerator(exEvent, handlers);
            LegendCopy  lPane = new LegendCopy(exEvent, handlers);
// set the dockpane classes to the instances to allow read/write to WPF //controls
            SheetGenPane = sPane;
            LegendCopyPane = lPane;
// register the dockablepanes
            application.RegisterDockablePane(SheetGenPaneId, "Sheet Generator", SheetGenPane as IDockablePaneProvider);
            application.RegisterDockablePane(LegendCopyPaneId, "Legends on Sheets", LegendCopyPane as IDockablePaneProvider);
            utilities.AddRibbonPanel(application);
            application.ControlledApplication.DocumentOpened += new EventHandler<Autodesk.Revit.DB.Events.DocumentOpenedEventArgs>(Application_DocumentOpened);
// actions for when a project is opened
        private void Application_DocumentOpened(object sender, DocumentOpenedEventArgs args)
            Document doc = args.Document;
            cDoc = doc;
            UIApplication UIApp = new UIApplication(doc.Application);
            try
// utility that loops through the dockpane instances and closes them
                utilities.Hidepanes(UIApp);
            catch(Exception ex)
                MessageBox.Show(ex.Message);
To open the dockablepanes, call dockpane.show from the command
    public class MultiSheet : IExternalCommand
        public Result Execute(ExternalCommandData commandData, ref string message, ElementSet elements)
            Document doc = commandData.Application.ActiveUIDocument.Document;
            Utilities utils = new Utilities();
// hide all the panes again
            utils.Hidepanes(UIApp);
// get the dockable pane you want to use
            DockablePane pid = UIApp.GetDockablePane(BIMApp.SheetGenPaneId);
// initialise the WPF controls through classes and functions
            utils.MakeLegendList(UIApp, BIMApp.SheetGenPane.LegendSelectorListView);
            utils.MakeSheetList(UIApp, BIMApp.SheetGenPane.SheetTamplateSelectorListview);
            utils.MakeTitleBlockList(UIApp, BIMApp.SheetGenPane.TitleBlockSelector);
            utils.MakeSheetParameterList(UIApp);
            utils.ViewParametersList(UIApp, BIMApp.SheetGenPane.ViewFilterParameterCombo);
            utils.MakeViewList(UIApp, BIMApp.SheetGenPane.ViewSelectionList, BIMApp.SheetGenPane.ViewFilters, "Family");
            utils.MakeLevelGrid(UIApp, BIMApp.SheetGenPane.LevelSettings);
// show the correct dockable pane for the current command
            pid.Show();
            UIApp.ViewActivated += UIApp_ViewActivated;
// function to handle views changing in the editor
        private void UIApp_ViewActivated(object sender, ViewActivatedEventArgs e)
            UIApplication UIApp = sender as UIApplication;
            if (UIApp != null)
                ViewType vt = e.CurrentActiveView.ViewType;
                if (vt == ViewType.DrawingSheet)
                    BIMApp.SheetGenPane.SheetParameterDataGrid.IsEnabled = true;
                else
                    BIMApp.SheetGenPane.SheetParameterDataGrid.IsEnabled = false;
          //  throw new NotImplementedException();
Here's the function for hiding the DockablePanes:-
        public void Hidepanes(UIApplication application)
            List<DockablePaneId> dockablePanes = BIMApp.DockPanes();
// Loops the static list defined in the main appliction
            foreach (DockablePaneId dPID in dockablePanes)
                DockablePane dpn = application.GetDockablePane(dPID);
                dpn.Hide();
These examples are a bit long winded but they are from an active application project with multiple dockable panes where reopening Revit is not an option. Hope this helps.
jeremy_tammik
Short answer: yes, you can implement an external application and subscribe to the DocumentOpened event:
https://www.revitapidocs.com/2023/b9415c2d-442e-f61d-aafa-de31cce7959b.htm
coopgodd
Thanks for the response! This will be super helpful.
coopgodd
Thanks for the in depth examples and everything! Much appreciated. I'll be sure to imitate parts of your code in my own, you have some great ideas.
