Only one instance addin plugin
sonicer
sonicer
How can I protect run only one instance of addin plugin?
If user run Revit 2018 and Revit 2019 on same PC...need protect only one instance.
jeremytammik
What is 'protect run'?
What do you mean by 'protect'?
Jeremy Tammik
Developer Technical Services
The Building Coder
sonicer
Sorry, meant this.
Possibility run only one instance of plugin on PC.
If user run revit 2018 and 2019 on same PC allow run only one instance of plugin.
thx.
jeremytammik
You can easily support multiple versions of Revit with one single add-in.
If the Revit API calls you make have not changed between Revit 2018 and Revit 2019, simply use the same add-in for both, compiled for Revit 2018.
If the API calls that you use have changed, you can handle that using .NET Reflection:
Jeremy Tammik
The Building Coder
sonicer
thx...But I think you talking about compiling plugin for multi version of revit.
I mean allow run only one instance of plugin.
