Only can see partial drawing of my file
I used Revit 2014 student version with my Window 7 home premier machine, but the Revit slowed down my machine and kept telling me that my machine have memory issues.  Although I upgraded my memory to 8GB and cleaned up my system, the situation does not improve.  So, I upgraded my system to Window 8 and reinstalled the Revit 2014, but I only can see partial of my  file now.  Does anyone know how to fix it?  Please help.  Attached please find my file for you to see my problems.  Thank you.
jeremytammik
Dear Thuang408,
Please note that this discussion forum is dedicated to programming Revit using the Revit API.
Therefore, you cannot expect an answer to a question such as yours relating to installation, product usage or end user support issues here.
You should try the Revit product support discussion forum instead for that.
I hope this clarifies.
Thank you for your understanding.
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
