Offset XYZ points
Offset XYZ points
Offset XYZ points
I have an array of XYZ point.
How to calculate offset points by some distance in outward or inward direction without creating line?
need to get all offset points
jeremytammik
No, of course not.
Without creating the line, at least in your imagination, there is no way to determine in which direction to offset each point.
However, the functionality you seek is provided by the Revit API CreateViaOffset method:
https://apidocs.co/apps/revit/2019/6cffc624-d197-0f3b-b68c-26b9c9a0adf8.htm
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
Thanks for your prompt reply.
Got solution.
public List<XYZ> GetOffsetPoints(List<XYZ> lstPoints, double offset)
List<XYZ> lsttmpPoints = new List<XYZ>();
try
CurveLoop cl = new CurveLoop();
for (int i = 0; i < lstPoints.Count; i++)
XYZ startPoint = lstPoints[i];
XYZ endPoint = lstPoints[0];
if (i == lstPoints.Count - 1)
else
endPoint = lstPoints[i + 1];
Line line = Line.CreateBound(startPoint, endPoint);
cl.Append(line);
CurveLoop cl1 = new CurveLoop();
cl1 = CurveLoop.CreateViaOffset(cl, offset, new XYZ(0, 0, lstPoints[0].Z + 1));
for (int i = 0; i < cl1.Count(); i++)
Curve cv = cl1.ElementAt(i) as Curve;
lsttmpPoints.Add(cv.GetEndPoint(0));
catch (Exception ex)
lsttmpPoints = lstPoints;
return lsttmpPoints;
jeremytammik
With this solution, I assume that your points form a curve loop in the XY plane.
Here is a slight cleanup of your solution:
    /// <summary>
    /// Create a new CurveLoop from a list of points.
    /// </summary>
    public static CurveLoop CreateCurveLoop(
      List<XYZ> pts )
      int n = pts.Count;
      CurveLoop curveLoop = new CurveLoop();
      for( int i = 1; i < n; ++i )
        curveLoop.Append( Line.CreateBound(
          pts[i - 1], pts[i] ) );
        pts[n], pts[0] ) );
      return curveLoop;
    /// <summary>
    /// Offset a list of points by a distance in a
    /// given direction in or out of the curve loop.
    /// </summary>
    public static IEnumerable<XYZ> OffsetPoints(
      List<XYZ> pts,
      double offset,
      XYZ normal )
      CurveLoop curveLoop = CreateCurveLoop( pts );
      CurveLoop curveLoop2 = CurveLoop.CreateViaOffset(
        curveLoop, offset, normal );
      return curveLoop2.Select<Curve, XYZ>(
          c => c.GetEndPoint( 0 ) );
Cheers,
Jeremy
Jeremy Tammik
The Building Coder
