Get Room Boundary.
Get Room Boundary.
Get Room Boundary.
Hello Everyone .
i want to get the Location point of Room Boundary Walls.
i don't know where to start ..can anyone give me some hints..
pls help.
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @Anonymous ,
try using this link
Room-and-wall-adjacency
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
Thankyou
BoundarySegmentArrayArray
BenoitE&A
A Room can have multiple loops in its contour, for example if you consider a room with a hole in the middle (duct).
So the room contour is an Array of Arrays of Boundary Segments :
- first array : consider the different loops (for example loop 1 : the exterior contour of your room - loop2 : the contour of the duct)
- second array : consider one closed loop and get every item of it.
- Boundary Segments : one piece of a contour containing mainly a Curve and Id of the element that creates it.
If you want to access the boundary segments of the first loop :
foreach(BoundarySegment bs in myRoom.GetBoundarySegments()[0])
Benoit FAVRE
CEO of etudes & automates
www.etudesetautomates.com/
Thankyou  BenoitE&A for reply.
I try this.
for each(Element ^element in collector)
Room ^room = (Room^)element;
IList<IList<BoundarySegment^>^>^ bsArr = room->GetBoundarySegments(gcnew SpatialElementBoundaryOptions());
for each(BoundarySegment ^bs in bsArr[0])
       bs->Element;/////Error
again Same Problem that BoundarySegment in not available after Revit 2015.
http://www.revitapidocs.com/2018/acf05037-5c49-9983-09d1-8d2eceed7c55.htm
and i try to cast the 'bs' into Element and Wall class but gives exception InvalidCastException.
pls help.
