Obtain InsertionPoint (same as in FamilyEditor) from CurtainPanel
lwlXUTTT
lwlXUTTT
Dear Community,
as in the Title,
CurtainPanel does not have LocationPoint, when placed in the Project
is there a way to obtain XYZ (in project coordinates), which would correspond to insertion point (which is visible in Family Editor) of CurtainPanel family instance?
Thank you in advance...
acrisanY67H6
Use LocationCurve to extract the information you need for your CurtainPanel element(s):
// el - your CurtainPanel element
Autodesk.Revit.DB.Location position = el.Location;
Autodesk.Revit.DB.LocationCurve positionCurve = position as Autodesk.Revit.DB.LocationCurve;
XYZ startPoint = positionCurve.Curve.GetEndPoint(0);
XYZ endPoint = positionCurve.Curve.GetEndPoint(1);
// etc.
lwlXUTTT
Unfortunately this is not the answer to the question...
I can easily get the startPoint and endPoint of LocationCurve of Host Curtain Wall...
But how can I get the insertion point of the CurtainPanel (as it is in Family Editor)?
