Hello everyone! Happy Holidays!: I am using Visual Studio 2019 Community, C# language. I am trying to implement the Hello World program in Revit 2019 just as it is explained in the Autodesk 2019 Revit 2019 walkthrough. Let me show you pictures of my file locations and code:So the code builds in Visual Studio. But when I run the debugger nothing happens in Revit. No error messages, no External tool shows up...
Help would be appreciated!
Regards, Alejandro Peláez
Hi there. There are quite a few possibilities, but I think the most likely is that the manifest file (HelloWorld.addin) is pointing to an assembly that doesn't exist...
from the tutorial:
On the 4th line down, the Assembly points towards a .dll file that is located on D:\. Is there a file on your machine that is located at that path? If not, just edit this line to point towards the correct location (the .dll created when you compiled your code).
Hope this helps!
Hello and thanks for the reply!
From the manifest file: <Assembly>C:\Samples\HelloWorld\HelloWorld\bin\Debug\HelloWorld.dll</Assembly>
Since I have my file saved at this path I don´t think this is the issue.
Alejandro
My apologies for assuming. I hope you find out whats wrong.
Edit: Actually, are you sure thats correct?
from your build output posted above:
from your previous post:
Could the extra \HelloWorld\ be the issue?
