Not able to retrieve PushButtonData name
lrsmns
lrsmns
so i have this method where i create multiple buttons with the same command but different naming as the parameter:
public static void AddButtonsToPanel(RibbonPanel panel, List<(string name, string labelText, string IconPath, string ToolTip)> buttons, string commandClassName)
    var assembly = Assembly.GetExecutingAssembly();
    foreach (var button in buttons)
        var buttonData = new PushButtonData(button.name, button.labelText, assembly.Location, commandClassName)
            ToolTip = button.ToolTip,
            LargeImage = ImageUtility.LoadImage(assembly, button.IconPath)
        panel.AddItem(buttonData);
var toolTip = "";
var familyKategorien = new List<(string Name, string Text, string IconPath, string ToolTip)>
    ("IT - Ausstattung", "IT\nAusstattung", "IT.png", toolTip),
    ("Tische", "Tische", "Tische.png", toolTip)
ButtonUtilities.AddButtonsToPanel(panel, familyKategorien, "familyCmd");
#endregion
and i try to get the button's name through the component manager:
private void ComponentManager_PreviewExecute(object sender, EventArgs e)
    var buttonCaller = sender as Autodesk.Windows.RibbonButton;
    if (buttonCaller != null)
        Autodesk.Revit.UI.TaskDialog.Show("Debug",
                $"Button Properties:\n" +
                $"Name: {buttonCaller.Name}\n" +
                $"Text: {buttonCaller.Text}\n" +
                $"Id: {buttonCaller.Id}");
        Familien.Kategorie = buttonCaller.Name; // Assign Name to Kategorie
        if (string.IsNullOrEmpty(Familien.Kategorie))
            Autodesk.Revit.UI.TaskDialog.Show("Debug", "Familien.Kategorie is empty!");
However the result was null for everything except the text, shown in this pic:
Any insights or hints would be very appreciated!
Sean_Page
You may need to look for the buttonCaller.AutomationName
Sean Page, AIA, NCARB, LEED AP
Partner, Computational Designer, Architect
lrsmns
I tried it and it's still returning the Text value and not from Name
Sean_Page
Could you try casting to a RibbonItem vs RibbonButton and then use item.Source.Name?
Not exactly the same, but here is how I get or use buttons by name from the ribbon.
foreach(Autodesk.Windows.RibbonTab tab in Autodesk.Windows.ComponentManager.Ribbon.Tabs)
    if(tab.Name == SomeTabName)
        foreach(Autodesk.Windows.RibbonPanel panel in tab.Panels)
            if(panel.Source.Name.Equals(panelName, System.StringComparison.CurrentCultureIgnoreCase))
                foreach(Autodesk.Windows.RibbonItem item in panel.Source.Items)
                    if(item.AutomationName == buttonName)
                            //Do something here
