Nominal Weight
Nominal Weight
Nominal Weight
How to extract the Value of Parameter W for HSS section with Revit API?
foreach (Element e in new FilteredElementCollector(doc)
                     .OfClass(typeof(FamilyInstance))
                     .OfCategory(BuiltInCategory.OST_StructuralColumns)
                     .Where(m => m.Name.Contains("HSS"))   // select just HSS columns
                FamilySymbol fs = fi.Symbol;
                Family family = fs.Family;
                Parameter p = fi.LookupParameter("Nominal Weight");
                data += fi.Name + "   " +  family.Name + "  :  " + fs.Name + "   : " + fi.GetType ().ToString()+  "\n";
            TaskDialog.Show("BI Params",data);
jeremytammik
Your code looks fine.
If you see W in the element property window, you can just replace the string "Nominal Weight" by "W".
Jeremy Tammik
Developer Technical Services
The Building Coder
