.NETFramework,Version=v4.5,Profile=Client
vjaqpf
vjaqpf
He probado cuanta solución ha sido sugerida en la WEB y no he podido corregir el error. Cuando trato de instalar la versión 4.5, el mensaje es que ya está instalada. En el GAC aparecen las versiones 14.0 y 4.0. No he podido insertar la versión 4.5 mediante gacutil /i. Tampoco se corrige configuranto el nuevo  item app.config (supportedRuntime version="v4.0").
Cuál será la solución real ?  Gracias.
jeremytammik
Is your question related to the installation of Revit itself, as an end user, or is it related to programming Revit using the Revit API?
In any case, it sound like an installation issue to me.
For that, this is not the best place to ask such a question.
Please note that this discussion forum is dedicated to programming Revit using the Revit API.
Therefore, you cannot expect an answer to a question such as yours relating to installation, product usage or end user support issues here.
You should try one of the non-API Revit product support discussion forums instead for that:
https://forums.autodesk.com/t5/revit-api-forum/this-forum-is-for-revit-api-programming-questions-not...
The people there are much better equipped to answer your question than us programming nerds.
I hope this clarifies.
Thank you for your cooperation and understanding.
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
vjaqpf
Jeremy, thanks for your answer. The problem can be by installation or not.
I was working since 3 month ago and now begun to appear the message, when I
try to Run any Macro: ".NETFramework,Version=v4.5,Profile=Client" were not
found.... but that Framework is installed already. Why before it does not
occur ?. I'll search in others forums like you suggested. Thanks.
