I have an issue with using a logger such as nlog in a C# project that I use as an add-in in revit.
I can't create a log file with this logger, or even display the log in the console.
I try my config in another simple console project and it's work fine and when try it with the revit add-in it doesn't.
there is my nlog config file:
<?xml version="1.0" encoding="utf-8" ?> <nlog xmlns="http://www.nlog-project.org/schemas/NLog.xsd" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://www.nlog-project.org/schemas/NLog.xsd NLog.xsd" autoReload="true" throwExceptions="true" internalLogLevel="Info" internalLogFile="c:\Temp\nlog-internal.log"> <!-- optional, add some variables https://github.com/nlog/NLog/wiki/Configuration-file#variables --> <variable name="myvar" value="myvalue"/> <!-- See https://github.com/nlog/nlog/wiki/Configuration-file for information on customizing logging rules and outputs. --> <targets> <!-- add your targets here See https://github.com/nlog/NLog/wiki/Targets for possible targets. See https://github.com/nlog/NLog/wiki/Layout-Renderers for the possible layout renderers. --> <!--Write events to a file with the date in the filename.--> <target xsi:type="File" name="file" fileName="${basedir}/logs/log-${shortdate}.log" layout="${uppercase:${level}} ${longdate} : ${message}" archiveAboveSize="10240000" /> <target name="logconsole" xsi:type="Console" layout=" ${uppercase:${level}} ${longdate} : ${message}"/> </targets> <rules> <!-- add your logging rules here --> <!-- Write all events with minimal level of Debug (So Debug, Info, Warn, Error and Fatal, but not Trace) to "f"--> <logger name="*" minlevel="Debug" writeTo="file" /> <logger name="*" minlevel="Debug" writeTo="logconsole" /> </rules> </nlog>
log instance in each class i want to log
[Transaction(TransactionMode.Manual)] public class Base : IExternalCommand { private static Logger logger = LogManager.GetCurrentClassLogger();
Do I need to do anything else?
Thanks for any help!
I finally solved my problem, I put the solution in case another person needs it.
nlog didn't load the config file when launched with REVIT. so I add the file path with the method
LogManager.Configuration = new XmlLoggingConfiguration(YOURCONFIGFILEPATH);
@Anonymous thank you, I have the same problem - nlog don't create folder and log files. I noticed LogManager.Configuration was Null and try you method. But it not helps me, log files dont creates whatever. Do you know what could be the problem?
My config file:
autoReload="true"
throwExceptions="false"
internalLogLevel="Off" internalLogFile="c:\temp\nlog-internal.log">
<targets>
<target xsi:type="File" name="filedata" fileName="${basedir}/logs/${shortdate}.log"
layout="${longdate} ${uppercase:${level}} ${message}" />
</targets>
<rules>
<logger name="*" minlevel="Debug" writeTo="filedata" />
</rules>
</nlog>
And addin-code:
class CommandBatchPrint : IExternalCommand
public Result Execute(ExternalCommandData commandData, ref string message, ElementSet elements)
App.assemblyPath = System.Reflection.Assembly.GetExecutingAssembly().Location;
string nlogconfigpath = System.IO.Path.Combine(System.IO.Path.GetDirectoryName(App.assemblyPath), "NLog.config");
LogManager.Configuration = new NLog.Config.XmlLoggingConfiguration(nlogconfigpath);
logger.Debug("Print started");
Alexander Zuev
In BIM we trust
Facebook | Linkedin | Telegram
The following works for me:
string nlogConfigPath = System.IO.Path.Combine(System.IO.Path.GetDirectoryName(Assembly.GetExecutingAssembly().Location), "NLog.config");
LogManager.Configuration = new NLog.Config.XmlLoggingConfiguration(nlogConfigPath);
logger.Info("Info: The Add-in is starting");
