NewDimension-between pipe and wallface in RevitLinkInstance
SimonaQQ
SimonaQQ
I newdimension between the pipe and the face of the wall, and I can create it correctly.
However, when the wall is in revitlinkinstance, an exception "invalid number of references" will be thrown. I understand that the reference of wallface should be converted, so I use reference. Createlinkreference, but it has the same effect, and I used newmodelcurve to create the edgecurve of wallface to ensure that wallface is correct.
So, how should I handle the reference of wallface?
thank you
 ReferenceArray arr = new ReferenceArray();
                                        if (wallInfo.RevitLinkInstance is null)
                                            arr.Append(wallInfo.Face.Reference);
                                        else
                                            var xxx = wallInfo.Face.Reference.CreateLinkReference(wallInfo.RevitLinkInstance);
                                            arr.Append(xxx);
                                        arr.Append(new Reference(t));
                                        var dimension = doc.Create.NewDimension(doc.ActiveView, dimensionLine, arr, dimensionTypeList.FirstOrDefault());
jeremy_tammik
One generic approach to fix the error message that you mention was discussed in
https://thebuildingcoder.typepad.com/blog/2016/04/stable-reference-string-magic-voodoo.html
Reformat Stable Representation String for Dimensioning
Joshua Lumley added an important note on using the stable references to create dimensioning in his comment below:
When creating dimensions based on objects from linked files, you may see an error message saying Invalid number of references.
To resolve that, all you do is rearrange the string a little...
Many successful uses of this 'magic voodoo' have been discussed here in the forum since then, so that may help resolve your issue as well.
Good luck and Happy New Year!
Jeremy
SimonaQQ
thank you.
I tried to adjust the string of reference to the format of "fb332d47-8286-4829-bd40-46c26de8ebac-000258d5:0: rvtlink: 2796184:1: surface / 5", which is effective. No exceptions will be thrown, but it is not displayed in the view. I tracked the code and found that the dimension was created successfully, but it is not displayed in the view, and it is not found according to the ID, Moreover, it is not available in the Revit lookup. It is expected that the dimension line exceeds the view range, but it still cannot be displayed and understood after adjusting the position of the dimension line.
Can you help solve the following problem? thank you.
https://forums.autodesk.com/t5/revit-api-forum/how-to-hide-the-boundary-line-of-the-model/m-p/108494...
jeremy_tammik
Good to hear that the voodoo does its job once again. There are some existing threads on newly created dimensioning remaining invisible. I have nothing to add to Richard's take on the individual edge visibility.
