Newbie -Warning message
Hi guys,
I am a newbie and going through various tools such as My first Plugin and other links.
When I add the Reference to the RevitAPI.dll and RevitAPIUI.dll in MS Visual Studio I get a Warning as follows:
  Warning 1 There was a mismatch between the processor architecture of the project being built "MSIL" and the processor architecture of the reference    "RevitAPI", "AMD64". This mismatch may cause runtime failures. Please consider changing the targeted processor architecture of your project through    the Configuration Manager so as to align the processor architectures between your project and references, or take a dependency on references with a  processor architecture that matches the targeted processor architecture of your project.
The Build still works but the plugin does not. The fist time I tried a plugin I didnt get this message and the plugin did work so not sure what I did to mess it up ?
thanks, any advice greatly appreciated.
David
arnostlobel
Hello David,
Do not worry about that particular warning. It's caused by a bug in VS. We do get that very warning too for all our internal add-ins and API regression tests; some thousand+ projects. Presumably, the bug has been fixed in VS2013 and VS2015.
Cheers
Arno?t L?bel
Autodesk, Revit R&D
Arnošt Löbel
Thanks for your quick reply.
i can ignore it so, thats fine. i am uisng VS Comunity 2103.
this just means i must have done something else wrong so, since my plugin is not working.
Ths build is fine and i think my .Addin looks right so I am still stuck 🙂
I will have another look now that i know that is not the problem.
David
pteague
Are you a time traveller?
yes, clearly. its just so disappointing that Microsoft hasn't done more with VS in all that time!
