IsolateElementsTemporary
Hello
forgive me if this question has been posed before. Googled this, have not found the answer, must be overlooking it
I want to use the IsolateElementsTemporary method on the active View, and it works fine.
However, how do I reset this?
In Revit you could use the keyboard shortcur 'HR' which also works, so as a dirty solution i could send this to the active window
However, if there is an API method to do this, I would much prefer to use that
Surely, there is a way?
arnostlobel
I think you are looking for this:
View.DisableTeporaryViewMode (TemporaryViewMode.TemporaryHideIsolate);
Arno?t L?bel
Autodesk, Revit R&D
Arnošt Löbel
Works! As I said, I had to be overlooking something 🙂
Thanks for the reply
