New IFC Parameters Revit 2023 don't work.
h.bakkerPE58B
h.bakkerPE58B
Hello all,
Revit 2023 allows users to specify the Export Type to IFC as parameter on an object/type base.
However, I seem to be unable to use these parameters (the window doesn't pop up).
I'm allready on the latest patch. I've tried it with an empty template and it didn't work, it worked on the computer of a collegue. Any suggestions as to how I can fix this issue?
jeremy_tammik
Are you programming anything yourself using the Revit API? If not, you may be in the wrong place. For generic Revit questions, the other forums are more appropriate:
IFC specific issues are best discussed in the IFC forum:
