Need to create multiple families from on OBJ assembly
I used DirectShape to load the geometry from obj file. Model is coming good in Revit. However I want to create family for all components in OBJ file instead of having one family of all components and apply parameters to each individual family. If I separate OBJ for each component and create family from it, it becomes impossible to position the instance of these families so that I get the desired complete assembly.
Can you please suggest me the way to do that.
jeremytammik
Congratulations on making good progress.
You can use direct shape elements to create family definitions.
Here is a discussion of improving family performance by suppressing direct shape generation in certain views:
http://thebuildingcoder.typepad.com/blog/2018/01/directshape-topics-and-happy-new-year.html/#8
Here is a collection of other direct shape topics that should cover all you need to know:
http://thebuildingcoder.typepad.com/blog/about-the-author.html#5.50
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
