need help for creating auto dimension setting between grid and duct/pipes
esthervinitha
esthervinitha
I am developing a revit plugin for the first time in C# for auto dimension setting between grid and duct/pipes... I got an error in which I cannot convert Autodesk.Revit.DB.Curve to Autodesk.Revit.DB.XYZ
The code below:
u
[Transaction(TransactionMode.Manual)] 
    public class Dim : IExternalCommand 
  public Result Execute(ExternalCommandData commandData, ref string message, ElementSet elements) 
  Document doc = commandData.Application.ActiveUIDocument.Document;           
            View activeView = doc.ActiveView;              
 FilteredElementCollector collector = new FilteredElementCollector(doc, activeView.Id);          
      var ductAndChwElements = collector.OfCategory(BuiltInCategory.OST_DuctCurves).UnionWith(collector.OfCategory(BuiltInCategory.OST_PipeCurves)).WhereElementIsNotElementType().ToElements();                 
 var coreWalls = new FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_Walls).WhereElementIsNotElementType();                           coreWalls.Where(e => e.Name.ToLower().Contains("Core"));         
     var gridLines = new FilteredElementCollector(doc).OfCategory(BuiltInCategory.OST_Grids).WhereElementIsNotElementType();      
       using (Transaction t = new Transaction(doc, "set out Dimensions"))               
    t.Start();          
          foreach (Element element in ductAndChwElements)             
       LocationCurve curve = element.Location as LocationCurve;   
                                                 if (curve != null) 
   Reference nearestRef = FindNearestReference(doc, curve.Curve, coreWalls, gridLines);    
      if (nearestRef != null)  
              XYZ elementPoint = curve.Curve.GetEndPoint(0);                              
    XYZ refPoint = nearestRef.GlobalPoint;                                  
   Line dimensionLine = Line.CreateBound(elementPoint, refPoint);                                  
      ReferenceArray ra = new ReferenceArray();                                    
 ra.Append(nearestRef);                                 
     ra.Append(new Reference(element));                                   
 doc.Create.NewDimension(activeView, dimensionLine, ra);                            
  t.Commit();           
 return Result.Succeeded;          
 private Reference FindNearestReference(Document doc, Curve curve1,FilteredElementCollector coreWalls, FilteredElementCollector gridLines)       {                
 Reference nearestRef = null;             
 double minDistance = double.MaxValue;                
 foreach (Element Wall in coreWalls)          
 LocationCurve wallCurve = Wall.Location as LocationCurve;                   
             if (wallCurve != null)      
     double distance = curve1.Distance(wallCurve.Curve);                          
             if (distance < minDistance)                       
  nearestRef = new Reference(Wall);                               
  minDistance = distance;                        
  foreach (Element grid in gridLines)          
Curve gridCurve = (grid.Location as LocationCurve).Curve;                  
   if (gridCurve != null)                  
 double distance = curve1.Distance(gridCurve);                            
   nearestRef = new Reference(grid);                                 
 return nearestRef;          
jeremy_tammik
Dear Esther,
Thank you for raising the issue here after our email conversation. Your code would be more readable if you format it as code using the </> Insert/Edit code sample button above. Also, it is rather long. I do not see off-hand where the conversion might be that is causing an issue for you. Furthermore, there is a discrepancy between your title and the text; in the title, you talk about creating dimensioning, which is a pretty high-level question; the text only mentions a very low-level question on extracting a 3D XYZ point or vector from a curve.
To address the latter: you cannot convert a curve to an XYZ point, because they are different things. You could easily extract an infinite number of XYZ points or vectors from a curve, however. For instance, you could query the start, mid and endpoints, or any point or tangent vector along the curve.
I hope this helps clarify and move forward.
Best regards,
Jeremy
