Deleting parameters from revit family with check for it's usage
vlad_kolesnikov1
vlad_kolesnikov1
Hello! I would like to make a code that would allow to delete unwanted parameters (those, that are not used in dimensions/arrays/formulas). And I would like to know how does Revit check the parameter for being used in dimensions and arrays:
MarryTookMyCoffe
you may need to find every parameter that is read only and check if
GetAssociatedFamilyParameter
give you null, On this point I don't see better way to find this out.
I'm not sure if method
GetAssociatedGlobalParameter
work in family document
this unfortunately need some trial and error
do not worry it only gonna take Autodesk 5 years to fix bug
vlad_kolesnikov1
@MarryTookMyCoffe Thank you for reply! I already found that parameters have this property, which I use as one of checks:
AssociatedParameters.IsEmpty
But I still have some kind of trouble, because parameters that are responsible for materials are unreachable for me. I use this simple code:
var paramList = fm.GetParameters().Where(e => e.IsShared && e.StorageType != StorageType.ElementId).ToList();
MarryTookMyCoffe
I thing Parameters for materials are StorageType ElementId, so ! make you lose them
