Naviate in MagiCAD-model
tobbUZGU2
tobbUZGU2
Community Visitor
Community Visitor
Hi, with Revit im combining with magicad and naviate. i'm working with a client who are solely using magicad and dont want to use naviate. my question is wether or not i can use Naviate for certain things without it affecting the magicad system. I need confirmation that this will not corrupt the file in which the client is working. When i say certain functions i mean for example creating views or extracting PDF-files. Tasks which isn't affecting the model.
jeremy_tammik
Sorry, this is the wrong place for such a question. Afaict from your query, you are not doing anything programmatically yourself using the Revit API, just using the standard Revit user interface, or, rather, Naviate and MagiCAD. Please note that this discussion forum is dedicated to programming Revit using the Revit API. You will normally get more optimal answers to a question relating to product setup, optimisation, usage, best practices and other end-user support issues in one of the non-API Revit product support discussion forums instead:
https://forums.autodesk.com/t5/revit-api-forum/this-forum-is-for-revit-api-programming-questions-not...
However, in this case, I suggest that you contact the Naviate and MagiCAD vendors directly ask ask them for support.
