My Revit app can't find SQLite. dll
Message 1 of 19
I am trying to use SQLite in my c# app to store data but I got file not find althought I refenced in the app, put it in all possible folders.
What to do? See the image.
Replies (18)
Message 2 of 19
MarryTookMyCoffe
look at this https://forums.autodesk.com/t5/revit-api-forum/3rd-party-dll-in-revit-addin/m-p/7746443#M28372 and if you start from RevitManager it can not load it with referenced dll
do not worry it only gonna take Autodesk 5 years to fix bug
Message 3 of 19
JimJia
Hi usama, Please put SQLite.dll to the same folder with your external applicaiton "Licenses" dll. After that, your app will find the SQLite.dll when it runs.
Jim Jia
Autodesk Forge Evangelist
https://forge.autodesk.com
Developer Technical Services
Autodesk Developer Network
Email: Jim.Jia@autodesk.com
Message 4 of 19
Thank you for the answer. Actually it is there. When I add a refrence to the sqlite.dll in the Revit.exe directory it works.
Message 5 of 19
jeremytammik
Revit.exe directory is the key. Alternatively, use a .NET assembly resolver:
http://thebuildingcoder.typepad.com/blog/2014/05/rvtva3c-assembly-resolver.html
Cheers,
Jeremy
Jeremy Tammik
Autodesk Developer Network, ADN Open
The Building Coder
Message 6 of 19
Tripler123
Hi Jeremy,
i have the same problem. I try use Assembly.LoadFrom(Path.Combine(Path.GetDirectoryName(Assembly.GetExecutingAssembly().Location), "System.Data.SQLite.dll")); but don't working.
Message 7 of 19
I have the same problem. My plugin program run on Revit 2021. I make sure that Revit 2021 have not 'System.Data.SQLite.dll'. I don't know why tell me 'cannot load the dll'.
I haved try using 'Linq2Db' and 'EntityFramework' for sqlite to do, but I failed. If you have solution, please tell me.
Thinks!
Message 8 of 19
MarryTookMyCoffe
try read what path it give you back before calling dll.
Message 9 of 19
The dll path is valid. I guess that revit maybe not work well. My solution: Dapper+System.Data.SQLite.Core+DapperExtensions. You will can write lambda expression to do anything.
Demo: https://github.com/kelicto/HelloDapper. EntityFramework and Linq2Db cannot do that and throw exception.
Message 10 of 19
Sean_Page
I ran into issues recently in 2022 related to references that previously worked and turning on and using the Fusion Assembly Binding log viewer was a substantial help.
"Fuslogvw.exe (Assembly Binding Log Viewer) | Microsoft Docs" https://docs.microsoft.com/en-us/dotnet/framework/tools/fuslogvw-exe-assembly-binding-log-viewer
Sean Page, AIA, NCARB, LEED AP
Partner, Computational Designer, Architect
Message 11 of 19
joshua.lumley
SQlite is dependent on these two .net binaries that Revit does not load, therefore they also need to be loaded along with it:
Microsoft.WindowsAPICodePack.dll
Microsoft.WindowsAPICodePack.Shell.dll
Message 12 of 19
Maybe you are right. But why don't auto load them? 'Assembly.LoadFrom' method can auto load all required dlls. And the sqlite should give us all dlls.
Message 13 of 19
Please see my demo, it's very nice to assess sqlite db by lambda.
Message 14 of 19
joshua.lumley
What we're doing is API programming, unlike creating a standlone program there is no auto Loading and Revit is not going to load a single assembly unless explicitly told to do so.  When loading assemblies I'm careful to examine what has already been loaded in order to avoid double loading and creating a memory leak.
See if you can make sense of the below code, to get my meaning..
And do you have a link to the demo.
            if (AppDomain.CurrentDomain.GetAssemblies().Where(x => x.FullName == stringWindowsAPICodePack).Count() == 0)
                Assembly.Load(File.ReadAllBytes(path + "\\Microsoft.WindowsAPICodePack.dll"));
            if (AppDomain.CurrentDomain.GetAssemblies().Where(x => x.FullName == stringWindowsAPICodePackShell).Count() == 0)
                Assembly.Load(File.ReadAllBytes(path + "\\Microsoft.WindowsAPICodePack.Shell.dll"));
            //2 August 2019: End.
            Properties.Settings.Default.AssemblyNeedLoading = false;
            Properties.Settings.Default.Save();
Message 15 of 19
To access Sqlite db, I use System.Data.SQLite.dll.
I don't understand why should this.
Message 16 of 19
Sorry, it's invalid message. I don't know how to close it.
Message 17 of 19
joshua.lumley
Keep trying, your close to finding the solution.
Message 18 of 19
Hello @joshua.lumley ,
Thanks for your great answer it helped me a lot.
Could you tell me which using you need for the following snippet, and why it is needed? It seem to be working without.
 Best regards,
François R
Message 19 of 19
joshua.lumley
This code is in the IExternalCommand interface (when the user clicks a button) and only needs to be run once per session. The AssemblyNeedLoading variable is set to true on launch.
