My Revit Add-on for Revit 2016 is crashing on the load with Revit 2017
Revit 2017.  How to cure it ?
jeremytammik
Debug it and see what is causing the crash.
Nobody else will be able to tell you without doing the same thing, stepping through the source code.
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
Thank you, Jeremy.
When I am doing
  application.RegisterDockablePane(_userDockablePaneId, _applicationName, Application._thisApp.GetMainWindow() as IDockablePaneProvider);
I am getting
Could not load type 'Autodesk.Revit.UI.Rectangle' from assembly 'RevitAPIUI, Version=17.0.0.0, Culture=neutral, PublicKeyToken=null'.
This call worked for Revit Architecture 2016.
jeremytammik
Look at the documentation of the Rectangle class in the Revit API help file or online:
http://www.revitapidocs.com/2017/?query=Rectangle#searchModal
As you can see there, this class seems to have moved from the UI namespacein the Revit 2015 and 2016 APIs to DB in Revit 2017:
Cheers,
Jeremy
Jeremy Tammik
The Building Coder
