must declare a body
must declare a body
must declare a body
I am new to programming and i am trying to follow an example in the API Developer Guide (13-9: Labeling a Dimension). I am receiving the following error:
'DimLabel.DimLabel. Execute(Autodesk.Revit.UI.ExternalCommandData, ref string, Autodesk.Revit.DB.ElementSet)' must declare a body because it is not marked abstract, extern, or partial.
Please let me know how to fix this.  The code is attached.
Basically, no body is defined for your Execute method.  See the commented area below.  Uncomment the curly braces and put the body of the Execute method between them.
<snip>
        public Result Execute(
            ExternalCommandData commandData,
            ref string message,
            ElementSet elements);
// Body goes here
//       CreateLinearDimension(commandData.Application.ActiveUIDocument.Document);  // Or whatever
            public Dimension CreateLinearDimension (Document document)
<snip>
