Multi-version NUnit testing framework for Revit API.
ricaun
Advisor Advisor
Message 1 of 10
ricaun
Hello everyone, after some years of development my Test framework for Revit API is released.
ricaun.RevitTest is a multi-version NUnit testing framework for Revit API. Support Revit 2019 to 2025.
Features:
  • Run tests and debug using Visual Studio to execute tests inside Revit.
  • Open and Close Revit and dotnet test execution.
  • Auto detect Revit installation and no manual plugin installation required.
The whole project is open-source with all the utility packages.
The best way to start is download the sample project.
For help and discussion:
Luiz Henrique Cassettari
ricaun.com - Revit API Developer
AppLoader EasyConduit WireInConduit ConduitMaterial CircuitName ElectricalUtils
Replies (9)
Message 2 of 10
jeremy_tammik
Wow, brilliant! Thank you ever so much, @ricaun !  I wish you a happy and peaceful midwinter break!
Message 3 of 10
borkheather375
Thank you so much.
Message 4 of 10
soonhui
Coming from AUTOCAD/Civil 3D ( and writing plugins for Civil 3D), that's really great!
Any chance that you will port this to Civil 3D as well?
Ngu Soon Hui
I'm the Benevolent Dictator for Life for MiTS Software. Read more here
I also setup Civil WHIZ in order to share what I learnt about Civil 3D
Message 5 of 10
ricaun
I don't have the incentive to port to AutoCAD/Civil, the whole project does not worth, only if you create a command line application to use AutoCAD and make the test adapter to use that application.
That's already implemented in the TestAdapter, so I can change some configuration and run tests using Design Automation for Revit instead of the Revit desktop version.
That was the main goal of the project to enable to run locally with Revit for Desktop or in the cloud using Design Automation with the same test input.
Anyway you could create a discussion in the https://github.com/ricaun-io/ricaun.RevitTest/discussions.
I don't have so much knowledge with AutoCAD API to be able to find the similar implementation from Revit API to AutoCAD API.
Probably the first one would be to create a command line application to run tests in Design Automation for AutoCAD, that is less complex and not require to find AutoCAD in the local machine.
Using this package that already support Design Automation for AutoCAD: https://github.com/ricaun-io/forge-api-dotnet-oss.design.automation
Is the same one I'm using in the https://github.com/ricaun-io/ricaun.DA4R.NUnit to run tests using Design Automation for Revit. (The repo is in private at the moment.)
In the end you could sponsor the project, that's a good incentive. 🤘
Message 6 of 10
jeremy_tammik
Hi @ricaun ,
thank you very much for implementing and sharing this great tool!
I have one quick questions: I assume that you are aware of and have evaluated the Dynamo Revit Test Framework (RTF):
Can you confirm that, please, and possible share a word or two on what advantages ricaun.RevitTest offers over and above RTF and other prior unit testing frameworks?
Muito obrigado!
Jeremy
Message 7 of 10
ricaun
Hey @jeremy_tammik
The Dynamo Revit Test Framework (RTF) looks abandoned in GitHub and I don't think works with Revit 2025 that uses .NET Core.
Using ricaun.RevitTest is really convenient to be able to execute tests inside Visual Studio Test Explorer.
Some ricaun.RevitTest features would be:
  • Support multiple Revit versions (2019-2025) (Revit Preview)
  • Runs inside Visual Studio Test Explorer (dotnet test)
  • Do not require any manual plugin installation.
  • Support to run tests using Design Automation for Revit.
About running tests using Design Automation for Revit, I have a class session in DevCon Europe this year about ricaun.RevitTest.
Gonna share everything in my youtube channel.
Message 8 of 10
jeremy_tammik
Brilliant! Thank you very much for the very helpful and detailed in-depth explanation!
Good luck with your class at DevCon; sounds great!
Message 9 of 10
borkheather375
Thanks for sharing, I appreciate it.
Message 10 of 10
soonhui
Just to share with everyone, I did a more extensive writeup on how to run NUnit tests with AutoCAD/Civil 3D plugins. Feedbacks are welcome!
Ngu Soon Hui
