Multi-Target 2021 and 2022 Using MSBuild
- Mute
- Permalink
- Report
For those interested you can configure a .csproj to multi-target both 2021 and 2022 on .NET Framework 4.8 using MSBuild. I posted this on a comment in @jeremytammik's blog but figured it'd be useful here too.
The first task is to choose what .NET 4.8 add-in you want to actively program against. There can only be one active add-in per .NET framework as far as I know. In this example I'm setting my default to Revit 2022 using the custom 'RevitVersion' property if it hasn't been configured yet.
<Project Sdk="Microsoft.NET.Sdk.WindowsDesktop" InitialTargets="Test">
<PropertyGroup>
<TargetFrameworks>net461;net47;net472;net48</TargetFrameworks>
<Configurations>Debug;Release</Configurations>
<OutputPath>bin\$(Configuration)\</OutputPath>
<UseWindowsForms>true</UseWindowsForms>
<RevitVersion Condition=" '$(RevitVersion)' == '' ">2022</RevitVersion>
</PropertyGroup>
Next, define configurations changes per each version.
<PropertyGroup Condition=" '$(TargetFramework)' == 'net461' ">
<PlatformTarget>x64</PlatformTarget>
<DefineConstants>DEBUG;REVIT2018</DefineConstants>
<OutputPath>bin\$(Configuration)\2018\</OutputPath>
</PropertyGroup>
<PropertyGroup Condition=" '$(TargetFramework)' == 'net47' ">
<DefineConstants>$(DefineConstants);REVIT2019</DefineConstants>
<OutputPath>bin\$(Configuration)\2019</OutputPath>
</PropertyGroup>
<PropertyGroup Condition=" '$(TargetFramework)' == 'net472' ">
<DefineConstants>$(DefineConstants);REVIT2020</DefineConstants>
<OutputPath>bin\$(Configuration)\2020\</OutputPath>
</PropertyGroup>
<PropertyGroup Condition=" '$(TargetFramework)' == 'net48' And '$(RevitVersion)' == '2021' ">
<DefineConstants>$(DefineConstants);REVIT2021</DefineConstants>
<OutputPath>bin\$(Configuration)\2021</OutputPath>
</PropertyGroup>
<PropertyGroup Condition=" '$(TargetFramework)' == 'net48' And '$(RevitVersion)' == '2022' ">
<DefineConstants>$(DefineConstants);REVIT2022</DefineConstants>
<OutputPath>bin\$(Configuration)\2022</OutputPath>
</PropertyGroup>
Next, load the proper dll references for each version.
<ItemGroup Condition=" '$(TargetFramework)' == 'net461' ">
<Reference Include="AdWindows">
<HintPath>C:\Program Files\Autodesk\Revit 2018\AdWindows.dll</HintPath>
<EmbedInteropTypes>false</EmbedInteropTypes>
<Private>false</Private>
</Reference>
<Reference Include="RevitAPI">
<HintPath>C:\Program Files\Autodesk\Revit 2018\RevitAPI.dll</HintPath>
</Reference>
<Reference Include="RevitAPIUI">
<HintPath>C:\Program Files\Autodesk\Revit 2018\RevitAPIUI.dll</HintPath>
</Reference>
</ItemGroup>
<ItemGroup Condition=" '$(TargetFramework)' == 'net47' ">
<HintPath>C:\Program Files\Autodesk\Revit 2019\AdWindows.dll</HintPath>
</Reference>
<HintPath>C:\Program Files\Autodesk\Revit 2019\RevitAPI.dll</HintPath>
<Private>False</Private>
</Reference>
<HintPath>C:\Program Files\Autodesk\Revit 2019\RevitAPIUI.dll</HintPath>
</Reference>
</ItemGroup>
<ItemGroup Condition=" '$(TargetFramework)' == 'net472' ">
<HintPath>C:\Program Files\Autodesk\Revit 2020\AdWindows.dll</HintPath>
</Reference>
<HintPath>C:\Program Files\Autodesk\Revit 2020\RevitAPI.dll</HintPath>
</Reference>
<HintPath>C:\Program Files\Autodesk\Revit 2020\RevitAPIUI.dll</HintPath>
</Reference>
</ItemGroup>
<ItemGroup Condition=" '$(TargetFramework)' == 'net48' And '$(RevitVersion)' == '2021' ">
<HintPath>C:\Program Files\Autodesk\Revit 2021\AdWindows.dll</HintPath>
</Reference>
<HintPath>C:\Program Files\Autodesk\Revit 2021\RevitAPI.dll</HintPath>
</Reference>
<HintPath>C:\Program Files\Autodesk\Revit 2021\RevitAPIUI.dll</HintPath>
</Reference>
</ItemGroup>
<ItemGroup Condition=" '$(TargetFramework)' == 'net48' And '$(RevitVersion)' == '2022' ">
<HintPath>C:\Program Files\Autodesk\Revit 2022\AdWindows.dll</HintPath>
</Reference>
<HintPath>C:\Program Files\Autodesk\Revit 2022\RevitAPI.dll</HintPath>
</Reference>
<HintPath>C:\Program Files\Autodesk\Revit 2022\RevitAPIUI.dll</HintPath>
</Reference>
</ItemGroup>
At the end, you need to configure an additional build for whatever .NET 4.8 Revit add-in you didn't set as the default above. This is nice because it will catch build errors even though the active .NET 4.8 version is something else.
<Target Name="Test">
<Message Importance="high" Text="-- Building $(MSBuildProjectFile), TF = $(TargetFramework), Config = $(Configuration), Revit Version = $(RevitVersion) --" />
</Target>
<Target Name="Build2021" BeforeTargets="DispatchToInnerBuilds">
<Message Importance="high" Text="*** running pre-dispatch builds ***" />
<MSBuild Projects="myProject.csproj" Properties="Configuration=$(Configuration);TargetFramework=net48;RevitVersion=2021"></MSBuild>
</Target>
Side note: Using a multi-target solution means you need to keep references to all the old versions of Revit. Be sure to copy out the needed dlls before removing that Revit version from your machine.
Hope this helps.
