Multi line text in a schedule programmatically.
We use to make the multi line in a schedule using ctrl return. How to do that programmatically?
jeremytammik
First of all, create such text manually through the user interface and use RevitLookup to explore the Revit API view of the result. That may already provide the answer to your question.
Jeremy Tammik
Developer Technical Services
The Building Coder
Thank you for the answer but you used to be more specific. Can you plz be this time also. Thanks!
jeremytammik
Have you installed RevitLookup? Have you examined a multi-line schedule entry with it? What do you see?
Jeremy Tammik
The Building Coder
