HELP! where is multi-segment grid modifing api that will change its curve?
I want to create a program that needs to modify multi-segment grid. I want to change its every segment freely.For example ,one idea is  to move one of the segments one end-point,  accordingly,the other end-point dont move,other segment move in parallel way . But in the API Reference Book , i only found create method about multi-segment grid.What could i do?  Hoping some master help me! thanks....
jeremytammik
Are you sure that what you are trying to do is possible at all?
How do you achieve your goal manually through the user interface?
In general, the Revit API supports nothing that cannot be done in the UI.
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
thank you for your reply! haha  i am a new comer ,not familiar with RevitAPI. I thought it can do everything with API.
jeremytammik
Welcome to the Revit API!
You cannot do everything, because programming a BIM follows strict rules to ensure consistency.
This applies to the user interface as well, of course.
Therefore, it helps a lot to understand the Revit product in depth from an end user point of view before even thinking of programming anything for it.
Once you have that understanding, the best way to get started with the Revit API is to work through the getting started material:
http://thebuildingcoder.typepad.com/blog/about-the-author.html#2
Cheers,
Jeremy
Jeremy Tammik
The Building Coder
