Message 1 of 13
12:28 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I need to make some changes to groups, so I am going the route of ungrouping, regrouping, and changing types. Unfortunately, this leads to some group origins being moved from their original group location. Is there any way to set where the group origin is by the Revit API? I'm don't want to move the groups, just their origin point as you can in the UI.
I've seen these threads from 2015 & 2016, but I wasn't sure if this functionality was added tot he API or not:
https://forums.autodesk.com/t5/revit-api-forum/set-xyz-point-for-model-group/m-p/6331903
Does anyone have a good workaround for doing this if it is not a API functionality?
Thanks!
