Modify Shared Parameters for high number of family instance
f.djiomejoungleroi.Ext
I have the code below working fine when my collection contain less than 30 objet; above 30 the transaction commit doesn't affect document and there is no error or exception raised. Did some one have an idea to solve this?
void IExternalEventHandler.Execute(UIApplication app)
	UIDocument uidoc = app.ActiveUIDocument;
	Document doc = uidoc.Document;
	View view = doc.ActiveView;
	using (Transaction tr = new Transaction(doc))
			Parameter param1 = null;
			Parameter param2;
			Parameter param3 ;
			Parameter param4 = null;
			Parameter param5 = null;
			Parameter param6 = null;
			Parameter param7 = null;
			tr.Start("synchro");
			for(int i = 0; i < Main.idForSynchros.Count; i++) // Main.idForSynchro is the collection of data
				IdForSynchro idForSynchro = Main.idForSynchros[i];
				Element element = doc.GetElement(new ElementId(Convert.ToInt32(idForSynchro.RevitId)));
				param1 = element.LookupParameter("PLUGIN_PARAM1");
				param2 = element.LookupParameter("PLUGIN_PARAM2");
				param3 = element.LookupParameter("PLUGIN_PARAM3");
				param4 = element.LookupParameter("PLUGIN_PARAM4");
				param5 = element.LookupParameter("PLUGIN_PARAM5");
				param6 = element.LookupParameter("PLUGIN_PARAM6");
				param7 = element.LookupParameter("PLUGIN_PARAM7");
				if (param1.AsInteger() < 1)
					param1.Set(idForSynchro.param1);
				string param6Value = DateTime.Parse(idForSynchro.data.param6, CultureInfo.InvariantCulture).ToLongDateString();
				string param7Value = DateTime.Parse(idForSynchro.data.param7, CultureInfo.InvariantCulture).ToLongDateString();
				Utils.SetParameterValueString(param2, idForSynchro.data.param2);
				Utils.SetParameterValueString(param3, idForSynchro.data.param2);
				Utils.SetParameterValueString(param4, idForSynchro.data.param4);
				Utils.SetParameterValueString(param5, idForSynchro.data.param5);
				Utils.SetParameterValueString(param6, param6Value);
				Utils.SetParameterValueString(param7, param7Value);
			tr.Commit();
// Method of Utils class that set Parameter value
 public static void SetParameterValueString(Parameter parameter, string value)
	if (parameter != null)
		parameter.Set(value);
jeremytammik
LookupParameter is unnecessarily costly.
There is no need to re-execute it for every parameter on every single element.
That is costing you a lot of time and hurting performance.
Every shared parameter is equipped with a GUID to identify it.
Determine the GUID once only on the first element.
Then, you can use the GUID to retrieve each parameter directly from the element without any LookupParameter searching through the entire list of parameters each time.
Here is my suggestion for an improvement:
    class IdForSynchro
      public ElementId RevitId { get; set; }
      public int Param1 { get; set; }
      public string Param2 { get; set; }
      public double Param3 { get; set; }
    void modifyParameterValues( Document doc, IList<IdForSynchro> data )
      using( Transaction tr = new Transaction( doc ) )
        Guid guid1 = Guid.Empty;
        Guid guid2 = Guid.Empty;
        Guid guid3 = Guid.Empty;
        tr.Start( "synchro" );
        foreach( IdForSynchro d in data )
          Element e = doc.GetElement( d.RevitId );
          if( Guid.Empty == guid1 )
            guid1 = e.LookupParameter( "PLUGIN_PARAM1" ).GUID;
            guid2 = e.LookupParameter( "PLUGIN_PARAM2" ).GUID;
            guid3 = e.LookupParameter( "PLUGIN_PARAM3" ).GUID;
          e.get_Parameter( guid1 ).Set( d.Param1 );
          e.get_Parameter( guid2 ).Set( d.Param2 );
          e.get_Parameter( guid3 ).Set( d.Param3 );
        tr.Commit();
I added this code in the original and updated forms to The Building Coder samples.
Here is the diff between the two:
https://github.com/jeremytammik/the_building_coder_samples/commit/fea7381f51b660fc9b5660c2e64f548623...
Here is the current code there:
https://github.com/jeremytammik/the_building_coder_samples/blob/master/BuildingCoder/BuildingCoder/C...
Please let us know whether this helps.
Please equip your code with a little benchmark timer stopwatch and let us know the processing time required before and after making this modification.
Thank you!
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
Thank you Jeremy,
I apply the solution and got  execution time improved. here is some results before and after the modification.
Number of Family instance
Time before (ms)
Time After(ms)
58
896
794
375
1958
1549
1052
16777
8152
But there are always times when changes are not applied to the document.
Sean_Page
Not sure if you caught it when you refactored, but in your original code you used param2 to set 2 and 3. Could that be affecting what your results are?
May be good to throw in some Try/Catch block to try and see where or if it's failing or at least a Task dialog to tell user if a param is missing.
Sean Page, AIA, NCARB, LEED AP
Partner, Computational Designer, Architect
