Modify RVT files
Modify RVT files
Modify RVT files
Is it possible to modify RVT files with the Revit API without having Revit running? Is there an OpenDWG equivalent to Revit that will allow me to modify RVT files from other applications?
jeremytammik
Dear Derek,
Thank you for your query.
The short answer tyo your question is simply 'No'.
A longer and more detailed answer is provided by the Revit API Developers Guide, e.g. here:
http://help.autodesk.com/view/RVT/2015/ENU/?guid=GUID-600856C0-DE79-4C70-8F27-431AFC6B1DA2
I hope this helps.
Best regards,
Jeremy
Jeremy Tammik
Developer Technical Services
Autodesk Developer Network, ADN Open
The Building Coder
Jeremy,
     Thank you for your response. Is there a roadmap for this? It's quite frustrating that Revit has such limited integration with other Autodesk software and that there isn't a non-application API available for developers to help bridge the gap.
jeremytammik
Dear Derek,
I really cannot say. You would have to discuss that with the product managers. I am sorry you find it frustrating. I can assure you there are good reasons for it.
Best regards,
Jeremy
Jeremy Tammik
The Building Coder
