I was trying to modify the "Scale Value 1:" parameter on a Viewport, when I realized it's ReadOnly so it is not possible to modify through the API, but it is also UserModifiable and I can easily change the scale of the Viewport in the GUI.
It's a bit confusing, I found some stuff about these parameters but found no solution.
But these articles only talk about how it's weird, and contain no solution.
I also tried using:
viewport.GetBoxOutline().Scale(x);
but with no luck, it just does not modify the scale.
So currently there is just no way to modify the scale and other ReadOnly-UserModifiable parameters or am I just missing something and did not look deep enough?
Solved by stever66. Go to Solution.
Here is an example of how to change the scale:
And here is a macro I tried that works. It assumes the current view is the one you want to change.
public void ChangeViewScale()
UIDocument uidoc = ActiveUIDocument;
Document doc = ActiveUIDocument.Document;
Autodesk.Revit.DB.View pView = ActiveUIDocument.Document.ActiveView;
using (Transaction transView = new Transaction(doc, "Set Param"))
transView.Start();
string message = null;
int testScale = 100;
pView.Scale = testScale;
message += "\nView name: " + pView.ViewName;
message += "\nScale after set: " + pView.Scale;
TaskDialog.Show("Revit", message);
transView.Commit();
You may find that you can't modify the scale of a ViewPort (though you can try setting the View Scale parameter as suggested above, that may work)
The reason I suggest this is that the ViewPort is really just showing you the scale of the DBView that it owns (or that it "expresses" depending on how you want to look at it).
You may find that getting the DBViewId (from the ViewId param on ViewPort) and then revitDoc.GetElement(myViewPort.ViewId) setting its "Scale" property is what you really want to do.
Thanks guys, yep I was trying to set the scale on the ViewPort not the view itself, and also I was checking the wrong parameter...
Now I use the view to set the scale and it works just fine.
