Modeless Form SDK Sample - 2 Requests for one single button
tiagofrbr
tiagofrbr
Hi!
I've been studying the sample ModelessForm_ExternalEvent from SDK and I would like to know how to make two requests in one single button click. It would be something like the code below, however only the latter request seems to be executed.
private void UpdateButton_Click(object sender, EventArgs e)
    CheckedListBox.CheckedItemCollection checkedItems = DiagramsListBox.CheckedItems;
    if (checkedItems.Contains("Terminal Circuits"))
        MakeRequest(RequestId.UpdateTerminalCircuits);
    if (checkedItems.Contains("Panel Data"))
        MakeRequest(RequestId.UpdatePanelData);
Michael_Coffey_G
You can make a static Data class with static properties to store info to pass between your form and the RequestHandler.  Utilize one RequestId and store the checked items in a static property.  On the RequestHandler side, process them as a list of items.  Clear the list after you've used them.
