Model Quality Checker
IbrahimNaeem
IbrahimNaeem
I have corrupted elements inside of my Revit Document, is there a workflow inside of the revit Api to ensure an element is corrupt or not ? any ideas?
Thanks, Ibrahim Naeem
Dale.Bartlett
We had one corruption case where an Element ID was listed in the journal as "Moribund" (near death - I had to look it up). We used the API to force a deletion of the ID that could not be done through the UI. Dale
______________
Yes, I'm Satoshi.
IbrahimNaeem
@Dale.Bartlett you're lucky then that only on element is corrupt, I have many elements deleted whatever shown and still couldn't save the file either standalone file or work-shared enabled so I'm thinking of a procedure by which I should detect the errors in the revit docs before getting worse as regular procedure that's to be done weekly for example.
