Missing classes in Autodesk.Revit.DB.IFC Namespace
I'm working on a custom IFC exporter for Revit and I had problems with the IFCExportOptions.AddOption() method which seems to work only under some circonstances (that I don't know yet). Then I saw on the Revit API documentation a section about the Autodesk.Revit.DB.IFC namespace (here) with many usefull classes and options. Unfortunatly when I try to use it I have only these 3 choices :
The documentation seems to stop at Revit 2018.1 and I'm using Revit 2018.3. Is it the problem ? Or do I forget to import some dll or extensions to the Autodesk.Revit.DB namespace ?
Thanks !
naveen.kumar.t
Autodesk Support
Autodesk Support
Hi @Anonymous,
Create an instance of IFCExportOption Class so that you can access it's methods and properties
IFCExportOptions IFC_export_options = new IFCExportOptions();
                IFC_export_options.AddOption(string name, string value);
RIFC.pngefer the image attached
Naveen Kumar T
Developer Technical Services
Autodesk Developer Network
As I said, I do have problems with the IFCExportOptions.AddOption() method. This is why I ask if a workaround exist using the Autodesk.Revit.DB.IFC.
The problem I have with IFCExportOptions.AddOption() is the following :
I can't find a configuration where rooms are exported as IFCSPACE.
My code : (Python)
options = IFCExportOptions()
    options.FileVersion = IFCVersion.IFC4RV
    options.WallAndColumnSplitting = False
    options.AddOption("ExportVisibleElementsInView", "true")
    options.AddOption("ExportRoomsInView", "true")
    options.AddOption("ExportInternalRevitPropertySets", "true")
    options.AddOption("ExportIFCCommonPropertySets", "true")
    options.ExportBaseQuantities = True
    options.AddOption("ExportAnnotations", "false")
    options.AddOption("UseFamilyAndTypeNameForReference", "false")
    options.AddOption("ExportPartsAsBuildingElements", "false")
    options.AddOption("UseActiveViewGeometry", "false")
    options.AddOption("ExportSpecificSchedules", "false")
    options.AddOption("ExportBoundingBox", "false")
    options.AddOption("ExportSolidModelRep", "false")
    options.AddOption("ExportSchedulesAsPsets", "false")
    options.AddOption("ExportUserDefinedPsets", "false")
    options.AddOption("ExportUserDefinedParameterMapping", "false")
    options.AddOption("ExportLinkedFiles", "false")
    options.AddOption("IncludeSiteElevation", "false")
    options.AddOption("Use2DRoomBoundaryForVolume", "true")
 As I understand the AddOption method the same configuration is working well using the UI but is not working the API.
Regarding your first question, adding the RevitAPIIFC.dll reference should help.
Regarding the second one, there is some information in this thread:
https://forums.autodesk.com/t5/revit-api-forum/ifc-export-using-document-export-not-working/td-p/811...
Thanks !
I found out that using the IFCExportUI.dll situated in "C:\Program Files\Autodesk\Revit 2018\AddIns\IFCExporterUI " I can create a new instance of IFCExportConfiguration.
This way I have a more stable way to export IFC :
IFCExportConfiguration config = IFCExportConfiguration.CreateDefaultConfiguration();
selectedConfig.Name = "<Sofya Setup>";
selectedConfig.IFCVersion = IFCVersion.IFC2x3CV2;
selectedConfig.SpaceBoundaries = 1;
selectedConfig.ActivePhaseId = ElementId.InvalidElementId;
selectedConfig.ExportBaseQuantities = true;
selectedConfig.SplitWallsAndColumns = false;
selectedConfig.VisibleElementsOfCurrentView = false;
selectedConfig.Use2DRoomBoundaryForVolume = false;
selectedConfig.UseFamilyAndTypeNameForReference = true;
selectedConfig.ExportInternalRevitPropertySets = true;
selectedConfig.ExportIFCCommonPropertySets = true;
selectedConfig.Export2DElements = false;
selectedConfig.ExportPartsAsBuildingElements = true;
selectedConfig.ExportBoundingBox = false;
selectedConfig.ExportSolidModelRep = false;
selectedConfig.ExportSchedulesAsPsets = false;
selectedConfig.ExportUserDefinedPsets = false;
selectedConfig.ExportUserDefinedPsetsFileName = "";
selectedConfig.ExportLinkedFiles = false;
selectedConfig.IncludeSiteElevation = true;
selectedConfig.UseActiveViewGeometry = false;
selectedConfig.ExportSpecificSchedules = false;
selectedConfig.TessellationLevelOfDetail = 0;
selectedConfig.StoreIFCGUID = true;
selectedConfig.ExportRoomsInView = true;
config.ActiveViewId = activeViewId.IntegerValue;
config.UpdateOptions(IFCOptions, activeViewId);
IFCExportOptions IFCOptions = new IFCExportOptions();
string folder = @"D:\"; string name = DateTime.Now.ToString("yyyyMMddHHmmss") + "_" + Path.GetFileNameWithoutExtension(doc.PathName) + ".ifc"; using(Transaction tr = new Transaction(doc, "Export IFC")) { tr.Start(); doc.Export(folder, name, IFCOptions); tr.Commit(); }
As @Anonymous said the classes mentionned in my first questions are situated in the RevitAPIIFC.dll (not used at the end).
I think this method is more stable than the IFCExportOptions .AddOptions() which is very typo sensitive.
