IFC Export using Document.Export not working
dirk.neethling
Message 1 of 13
dirk.neethling
I'm exporting a model using Document.Export(String, String, IFCExportOptions). It always exports an empty project, with the same filesize, regardless of which IFCExportOptions I set.
The alternative would be using IExporterIFC (https://knowledge.autodesk.com/search-result/caas/CloudHelp/cloudhelp/2016/ENU/Revit-API/files/GUID-...). However, after referencing the dll, the compiler says that:
Error    120      The type or namespace name 'BIM' could not be found (are you missing a using directive or an assembly reference?)
No idea what to do.
Back to Document.Export: The result of the following code is an empty project, when reimporting into Revit 2017 (in order to verify):
                        IFCExportOptions IFCOptions = new IFCExportOptions();
                        IFCOptions.FileVersion = IFCVersion.IFC2x3;
                        IFCOptions.WallAndColumnSplitting = true;
                        IFCOptions.ExportBaseQuantities = true;
                        IFCOptions.FilterViewId = v.Id;
                        IFCOptions.AddOption("IFCVersion", "IFC 2x3 Coordination View 2.0");
                        IFCOptions.AddOption("ExportInternalRevitPropertySets", "true");
                        IFCOptions.AddOption("ExportAnnotations ", "true");
                        IFCOptions.AddOption("SpaceBoundaries ", "0");
                        IFCOptions.AddOption("VisibleElementsOfCurrentView ", "true");
                        IFCOptions.AddOption("Use2DRoomBoundaryForVolume ", "true");
                        IFCOptions.AddOption("UseFamilyAndTypeNameForReference ", "true");
                        IFCOptions.AddOption("ExportInternalRevitPropertySets ", "true");
                        IFCOptions.AddOption("ExportIFCCommonPropertySets", "true");
                        IFCOptions.AddOption("Exportuserdefinedpropertysets", "true");
                        IFCOptions.AddOption("Export2DElements", "false");
                        IFCOptions.AddOption("ExportPartsAsBuildingElements", "false");
                        IFCOptions.AddOption("ExportBoundingBox", "false");
                        IFCOptions.AddOption("ExportSolidModelRep", "true");
                        IFCOptions.AddOption("ExportSchedulesAsPsets", "false");
                        IFCOptions.AddOption("ExportLinkedFiles", "false");
                        IFCOptions.AddOption("IncludeSiteElevation", "true");
                        IFCOptions.AddOption("UseActiveViewGeometry", "false");
                        IFCOptions.AddOption("ExportSpecificSchedules", "false");
                        IFCOptions.AddOption("TessellationLevelOfDetail", "0.5");
                        IFCOptions.AddOption("StoreIFCGUID", "true");
                        IFCOptions.AddOption("ExportRoomsInView", "false");
                        //Export the model to IFC
                        doc.Export(TEMP, ifcname, IFCOptions);
Is there an example on the net of an IFC export which actually works? (not code snippets, files/features of mere interest, or tutorials which are irrelevant)
Replies (12)
Message 2 of 13
jeremytammik
I implemented such a sample for you just now and added it to The Building Coder samples:
https://github.com/jeremytammik/the_building_coder_samples
I implemented a new external command CmdExportIfc for it:
https://github.com/jeremytammik/the_building_coder_samples/blob/master/BuildingCoder/BuildingCoder/C...
You can see the changes I made for that by comparing with the previous version:
https://github.com/jeremytammik/the_building_coder_samples/compare/2019.0.142.1...2019.0.143.0
Here is the relevant code snippet:
  /// <summary>
  /// Export current view to IFC
  /// </summary>
  static Result ExportToIfc( Document doc )
    Result r = Result.Failed;
    using( Transaction tx = new Transaction( doc ) )
      tx.Start( "Export IFC" );
      string desktop_path = Environment.GetFolderPath(
        Environment.SpecialFolder.Desktop );
      IFCExportOptions opt = null;
      doc.Export( desktop_path, doc.Title, opt );
      tx.RollBack();
      r = Result.Succeeded;
    return r;
This is obviously following the KISS principle, which I always highly recommend doing:
https://en.wikipedia.org/wiki/KISS_principle
Cheers,
Jeremy
Jeremy Tammik
Developer Technical Services
The Building Coder
Message 3 of 13
dirk.neethling
Thanks Jeremy,
I downloaded your latest BuildingCoder version and am giving this a try.
Dirk
Message 4 of 13
dirk.neethling
Hello Jeremy,
I got the same result, the ifc-file is empty. Even when I set the view to the 3D view, using the code below (which I think is from one of your blog pages), I get an empty file.
Dirk
    /// <summary>
    /// Retrieve a suitable 3D view from document.
    /// </summary>
    static View3D Get3dView(Document doc)
        FilteredElementCollector collector
          = new FilteredElementCollector(doc)
            .OfClass(typeof(View3D));
        foreach (View3D v in collector)
            Debug.Assert(null != v,
              "never expected a null view to be returned"
              + " from filtered element collector");
            // Skip view template here because view
            // templates are invisible in project
            // browser
            if (!v.IsTemplate)
                return v;
        return null;
Message 5 of 13
jeremytammik
Then you probably have some other, more serious, non-API problem.
Does the export work from the user interface?
If not, please discuss and resolve the issue in the product support forums first.
Cheers,
Jeremy
Jeremy Tammik
The Building Coder
Message 6 of 13
dirk.neethling
Yes, it works from the User Interface.  No problem there.
Regards, Dirk
Message 7 of 13
jeremytammik
Sounds weird.
You might want to ask about this in the IFC open source project forum:
https://sourceforge.net/p/ifcexporter/discussion/general
Meanwhile, I also asked the development team on your behalf.
Cheers,
Jeremy
Jeremy Tammik
The Building Coder
Message 8 of 13
dirk.neethling
Hello Jeremy,
Thanks! As I mentioned before, I tried to get the custom export going, using [https://www.bim42.com/2017/09/using-the-revit-ifc-export-in-your-own-add-on/.]. However when I reference the IFCExportUI.dll, I get the compiler message:
Error    125    The type or namespace name 'BIM' could not be found (are you missing a using directive or an assembly reference?)
Sample code:
                        //Create an instance of IFCExportOptions
                        //Get an instance of IFCExportConfiguration
                        BIM.IFC.Export.UI.IFCExportConfiguration selectedConfig = BIM.IFC.Export.UI.IFCExportConfiguration.CreateDefaultConfiguration();//.Configuration;
                        //Get the current view Id, or -1 if you want to export the entire model
                        ElementId activeViewId = v.Id;
                        selectedConfig.ActiveViewId = selectedConfig.UseActiveViewGeometry ? activeViewId.IntegerValue : -1;
                        //Update the IFCExportOptions
                        selectedConfig.UpdateOptions(IFCOptions, activeViewId);
                        string folder = "A path to a folder where you want to save your IFC file";
                        string name = "the name of your IFC file";
                        doc.Export(folder, name, IFCOptions);
Regards, Dirk
Message 9 of 13
jeremytammik
Dear Dirk,
The namespace BIM is not part of the Revit API:
http://www.revitapidocs.com/2018.1/d4648875-d41a-783b-d5f4-638df39ee413.htm
It comes from some third-party component that I am not aware of and have no knowledge about.
That is why I always recommend KISS:
One important rule, always, for me at least: minimise dependencies and external components.
Cheers,
Jeremy
Jeremy Tammik
The Building Coder
Message 10 of 13
dirk.neethling
Why can I not reference the ExporterIFC class in my project:
http://www.revitapidocs.com/2018.1/c8697b81-e080-9202-14d3-ec883f951521.htm
Autodesk.Revit.DB.IFC.ExporterIFC  exp = null;
Error    125    The type or namespace name 'ExporterIFC' does not exist in the namespace 'Autodesk.Revit.DB.IFC' (are you missing an assembly reference?)
Message 11 of 13
jeremytammik
You need to reference the Revit API .NET assembly DLLs.
They live in the same folder as Revit.exe.
OK, first question - is he trying to do a standard IFC export (that is, using the built-in exporter), or is he trying to test his custom exporter?
Cheers,
Jeremy
Jeremy Tammik
The Building Coder
Message 12 of 13
dirk.neethling
I tried using the standard IFC Exporter. Regardless of the Document content, it generates an .ifc file with the same size, with NO content.
Since that did not work, regardless of IFCExportOptions-setttings, I tried using the custom exporter (calles “IFC for Revit”), see [https://www.bim42.com/2017/09/using-the-revit-ifc-export-in-your-own-add-on/]. But I cannot reference the dll IFCExportUI.dll (which lives under C:\Program Files\Autodesk\Revit 2017\AddIns\IFCExporterUI on my machine), even though I can see it and it has the same name as the one mentioned in the article.
So at this point I am stuck: The standard IFC-Export does not work, and I cannot get the custom code to compile.
Message 13 of 13
May be problem is not in IFCExporter. Try to open generated IFC file and in 3D view properties change "display phase" (not sure, I'm using non english localization) to some else.
