Merge Surface In Revit API
Hi ,
I've created the many toposurfaces through Revit API, Now I need to combine surfaces.
From the User Interface, in the Massing & Site>Merge Surfaces it is available, but I didn't find way to do same in Revit API.Merge Surfaces.JPG
Does anyone known a function or have an idea to do that, it will be appreciated?
Thanks In advance,
Sina.
mohamed.mo7ie
I have the same issue, have you got any luck to get that done?
I don't work with Site, but if you can pre-select the surfaces before selecting the 'Merge Surfaces' command, you could try remotely starting PostableCommand.MergeSurfaces.
Thanks James,
I didn't know about PostableCommand, I am going to try it.
