MEP Fabrication Pipework (Edit Parameter or More Parameter)
ncircle_a4
ncircle_a4
How can we get the values of MEP Fabrication connectors from more parameter or edit parameter selected using Revit API. Please refer to the attached snap for better understanding.
jeremy_tammik
The screen snapshot that you share is not showing parameters, but connectors. So, the title of your query has little to do with the screen snapshot. So, it is unclear what you really want. However, I can share the following code snippet that shows a possible way to access the name and group of the fabrication part connectors, which corresponds to your picture:
  FabricationConfiguration config
    = FabricationConfiguration
      .GetFabricationConfiguration(doc);
  ConnectorSet cons = fabrication_part.ConnectorManager.Connectors;
  foreach (Connector con in cons)
    FabricationConnectorInfo infoFabCon
      = con.GetFabricationConnectorInfo();
    int id = infoFabCon.BodyConnectorId;
    string sg = config.GetFabricationConnectorGroup(id);
    string sn = config.GetFabricationConnectorName(id);
    string s = sg + "_" + sn;
