MEP Calculated Values in Shared Parameter
HeinWelman
HeinWelman
Is there any way of calculating a value from two existing parameters and reporting it to a Shared Parameter by using the Revit API?
My aim is to use this in a Tag to display a different flow value through a pipe.
I have seen a plugin doing it for Room Area and occupancy.
The image attached shows the parameters i'm using,
"Pressure Factor" & CW Flow are Shared Parameters.
The result im looking for:
"Flow/Pressure Factor=CW Flow"
Joe.Ye
This is possible to be done by Revit API.
You can read the two shared parameters value first, then calculate the value Flow/Pressure Factor, finally assign the value to CW flow parameter.
here is the code fragment
Pipe pipe = null;
//pipe is the target pipe. retrieve one target pipe and assign it to pipe variable.
Parameter flowParam = pipe.get_Parameter("Flow");
Double flowValue = flowParam.AsDouble();
Parameer pressureParam = pipe.get_Parameter("Pressure Factor");
Double pressureValue = pressureParam.AsDouble();
double cw = flowValue/PressureValue;
pipe.get_Parameter("CW Flow").Set(cw);
Hope this helps.
Joe Ye
Contractor
Developer Technical Services
Autodesk Developer Network
