Material library not installing
Hi there,
my Revit material library is not loading into the projects. I have tried a 100 times to reinstall Revit   but it does not make any difference. I have also tried different versions (2020, 2021 and 2022, which is what I have now) on multiple computers and it is still the same. All materials are not loaded because I does not install them on my computers.
I need to find the material library folder download and link it to the program.  Can anybody Help?
jeremy_tammik
Unfortunately, this is not the best place to ask such a question.
Please note that this discussion forum is dedicated to programming Revit using the Revit API.
Therefore, you cannot expect an answer to a question such as yours relating to licensing, installation, product usage or end user support issues here.
You should try one of the non-API Revit product support discussion forums instead for that:
https://forums.autodesk.com/t5/revit-api-forum/this-forum-is-for-revit-api-programming-questions-not...
The people there are much better equipped to answer your question than us programming nerds.
I hope this clarifies.
Thank you for your cooperation and understanding.
Best regards,
Jeremy
